Temp gauge weird out please help!!!
Old 10-13-2009, 07:22 PM
juniorg26's Avatar
Ihave a 86 4runner with a cluster that has a tach the oil gauge not working and the temp gauge is weird cause when my car is cold I turn the key on the needle is on normal position like if the truck was warm already i unpluged the temp sensor from the termosthat and no diference what can ido to make it work right this is my daily driver
Old 10-13-2009, 07:28 PM
yotaman90's Avatar
Did the cluster with the tach come in the 4runner, or did you swap out the regular cluster for the one with the tach?
Old 10-13-2009, 08:41 PM
juniorg26's Avatar
I bought like that
Old 10-14-2009, 09:21 AM
yodta's Avatar
the '86 & '87 SR5 gauge clusters were known for screwy operation.
I had the same problem with mine. it would just bounce all over the place. imagine my reaction the first time I saw it peg out out of the blue! I installed an aftermarket one.
you can get one of Jeff Moskovitz's gauge cluster pillars to install it in. These look pretty cool.
I ordered the Auto Meter temp gauge from Summit Racing
Here are a few 2 1/16" ones to pick from. Comes with the sender. Pretty easy to install. Just threads into one of the plugged ports on the stock manifold.
The gauge I bought came with both green and red sleeves to match dash lighting.
Here's mine with my A/F meter in it and my Auto Meter temp gauge below.
Old 11-28-2009, 04:16 PM
TheExonerator's Avatar
Hey,
i have this problem also.
As a disclaimer, I'm a newbie.
Wondering if you fixed this and how. Maybe any tips for my job.
I was also thinking aftermarket gauge. How did you mount yours if you used one?
90YotaPU
09-21-2015 05:58 PM
jacked_72
09-14-2015 03:31 PM
imhousing
09-10-2015 02:04 PM
LucasF249
09-08-2015 01:17 PM
--Oz--
09-06-2015 01:06 AM
Quick Reply: Temp gauge weird out please help!!!
