taking off front rotors on 4x4
Old 04-22-2006, 03:25 PM
suecurrin7's Avatar
How do I take off the rotors on my 1994 4x4 truck? The one on the right side is in bad shape, It has a crack in it. I have replaced the brake pads on the left and it looked good, when I pulled off the wheel on the Rt it was bad, got to get the rotor off and get another one, Thanks for the help, Sue
Old 04-22-2006, 03:53 PM
eric-the-red's Avatar
Follow these instructions to remove the hub, and after you get it off you'll find 6 bolts at the back which need to be removed to seperate the rotor from the hub. They'll be very tight, when I did mine I put the hub into a wheel lying on the ground, stood on it and used a 24" breaker bar.
http://www.off-road.com/toyota/wheel_bearing.html
It's a big job, and you'll want to at least repack the wheel bearings, or replace them if they're worn.
Old 04-22-2006, 04:20 PM
suecurrin7's Avatar
Thank you, about how much do they cost?
Old 04-22-2006, 05:05 PM
It's been a while since I replaced mine, but I'd guess around $60 - $70 each.
Old 04-22-2006, 05:16 PM
AH64ID's Avatar
LCE has some drilled and vented rotors for $44 ea, I think
Old 04-22-2006, 06:36 PM
brandontrek's Avatar
go with the LC rotors...i have them and they stop on a dime!!! i love them!!
Old 04-23-2006, 07:45 AM
Elton's Avatar
i have power slot rotors on my truck and there awesome i think i paid around $240 for the 2 rotors and pads
Old 04-23-2006, 03:40 PM
suecurrin7's Avatar
will a 1988 4x4 rotor work on my 1994 truck. I got the rotor off today and a guy down the road has a 1988 4x4 wrecked truck that I can get the rotors for a song, If not what number do I order from LCE. I have a 1994 extend cab 4x4 with manual locking hubs. I don't think it is a Tomcma
lledwod
08-30-2016 01:03 PM
msane99
07-11-2015 08:08 PM
God's Bounty Hunter
07-08-2015 12:54 PM
toyoda8488
07-05-2015 10:18 PM
zd92655
07-05-2015 04:25 PM
Quick Reply: taking off front rotors on 4x4
