Tailgate arms driving me crazy
Old 12-11-2009, 01:51 PM
thedanned's Avatar
Im bored at work and have a burning question. It burns when I question?
Has anyone replaced the little bumper things that are supposed to keep the tailgate support arms from flopping around? All I hear is "clack clack clack clack" when I go around a corner or hit a bump. Its driving me nuts.
Old 12-11-2009, 01:55 PM
OrRunner's Avatar
i have an 87 runner that i replace the tailgate bump stops on but i think what your looking for i a little plastic washer type thing that goes between the bolt to hold the tailgate are in place and it keeps them from making noise, i think there is a thread on here but i believe you can only get them from the dealer
Old 12-11-2009, 01:56 PM
shaeff's Avatar
Yep, they're only a couple bucks from the dealer. A solution I've used several times is to zip tie a piece of foam to the arms, only a 1/2" x 1/2" square that's maybe 1/4" thick, and it stops them from moving around just fine. I had to do that on one side- it was driving me crazy until I got the parts. LOL.
Old 12-12-2009, 05:37 AM
rustypigeon's Avatar
I have been using zip ties for years to keep mine from rattling. I just put a zip tie around ONE of the arms on each side. The natural bend of the zip tie will put slight pressure on the other arm and that keeps them from rattling.
Old 12-12-2009, 07:21 AM
87AzRunner's Avatar
lmao i used some foam and duct tape
Old 12-12-2009, 08:07 AM
CHEEZBURGER's Avatar
Or just turn your radio up that's what my brother in law does
Old 12-14-2009, 09:34 AM
Stuwy123's Avatar
Anyone ever swap the arms out for a cable setup? Mine rattle like crazy, they drowned out my roll bar rattle.
Old 12-14-2009, 10:09 AM
Just Learning's Avatar
a cable set up ? not a bad idea, hope someone mabey has
Old 12-14-2009, 10:10 AM
4Crawler's Avatar
I replaced mine with the dealer parts and have had no rattles since.
Old 12-14-2009, 12:02 PM
thedanned's Avatar
Some good ideas! I searched after I posted this (imagine that) and found a thread where someone replaced the arms with cables, but could not find ones that were the exact same length, only slightly longer. So he put em on and now his tail gate swings lower than before. I think Im gonna go get some new ones from the dealer though.
thedanned's Avatar
Thats called the "squeak and rattle knob"!
Old 12-14-2009, 05:54 PM
myyota's Avatar
I have the same rattle noise on my 86 4Runner because one of the plastic clips is broken. When i was at pic n pull a couple of weeks ago i pulled some of those plastic clips from a 91 4Runner, there a little bit diferent but should work the same as the original ones.
Old 12-14-2009, 06:09 PM
camo31_10.50's Avatar
just make your own cable ones?????
i've seen a set a guy made, he used some aircraft grade wire (about 1/4" diameter) and had a machine guy put some ends on em..worked like a charm lol
Old 12-15-2009, 10:09 AM
Willie B's Avatar
I just stuck some thock washers on the bed side, and the tailgate side, they took up the "wollered" out space up, and too up a lot of the slack.
Old 12-20-2009, 06:34 PM
rynamite99's Avatar
A friend of mine used some(cables) out of a 02 tacoma. They are a bit longer and his tailgate isn't level, but it doesn't bother him. I bought some cables for a chevy (that were shorter than the tacoma cables) that I got from advanced auto. My tailgate is level with NO rattle!
Old 12-20-2009, 06:38 PM
B4Runner's Avatar
theres like a thin type of styrophome thing that my headphones for my yukon came in. u just took little sections of that, folded them up, and taked them on and rapped tape all over the arm to keep then in place. work like a charm.
bigjstang
08-25-2021 12:41 AM
jasonty
41
12-23-2018 01:00 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Tyler Cunningham
07-11-2015 10:18 AM
mickyd9990
07-06-2015 09:01 AM
Quick Reply: Tailgate arms driving me crazy
