supercharged 3.4 in 3rd gen
Old 05-16-2012, 01:49 PM
toyotanick's Avatar
i am having issues under boost and was wondering if anyone else has had this problem. because the 3.4 is not designed for my truck i was wondering if the factory fuel pump can handle the demands of the charger.
i am running a secondary fuel but am just wondering if any of you guys happen to know about the factory fuel pump.
Old 05-16-2012, 05:13 PM
snobdds's Avatar
I think most guys go up to a walbro fuel pump...which one I have no idea.
I know "Slacker" has some 3.4 with supercharger swap threads that has the answer to your question.
Old 05-17-2012, 06:42 AM
slacker's Avatar
I use the OE in my trekker , with no problems with fuel supply at all . I also had a bit of "ping" with 92 octane , so I now use 94 . havent had any problems at all , but i'm also not driving it every day ! .
walbro is your best option for fuel supply , and what is recommended by URD and others
Old 05-17-2012, 12:51 PM
totally a bro
Staff
vital22re's Avatar
the oem 3.0 fuel pump is not good enough. I ran it for a while but found out quickly it was maxing out just to keep up with the 2.3 oem pulley. Right after I upraded to a walbro 190 my afr's got richer almost a full point.
Old 05-18-2012, 04:50 PM
toyotanick's Avatar
wow, ok and i should definatelly be running premium also haha. i will immediately start looking into one of those 190 walbro's
my afr's are outrageous right now! I'm anywhere from 14 to 16 not in boost.
Old 05-18-2012, 05:09 PM
toyotanick's Avatar
is any 190 walboro the same thing? just making sure, because they also say some sort of make or model.
Old 05-18-2012, 05:17 PM
slacker's Avatar
http://treperformance.com/search.htm...yota+fuel+pump
try one of these
Old 05-18-2012, 05:30 PM
toyotanick's Avatar
so you are saying to use an external pump instead of mounting a new 190 inside of the tank?
Old 05-18-2012, 05:31 PM
slacker's Avatar
no .. these are internal pumps
Old 05-18-2012, 05:33 PM
slacker's Avatar
have a peek here
https://www.yotatech.com/forums/f209...-build-250286/
Old 05-18-2012, 07:22 PM
toyotanick's Avatar
very nice. my biggest difference is that i am bored out a little and that i am running methanol. but it only kicks in when there is boost just like the 7th. the methanol can't keep my afrs low because the truck itself has a stupid high afr before boost starts.
i will probably order the walboro 190 in a few minutes
Old 05-18-2012, 07:25 PM
toyotanick's Avatar
the only 190 pump is Item #: GSL-391 and 400-939 that is an inline pump.
Old 05-19-2012, 07:02 AM
toyotanick's Avatar
all of the pumps on this page are 255's i dont think that is necessary right? like i said, i am not running the 7th injector, i am running methanol injection so i dont need to push that extra injector.
Old 05-19-2012, 04:51 PM
slacker's Avatar
yep 190 will be just fine .. sorry , might not have been the best link to send you to
Old 05-19-2012, 07:47 PM
toyotanick's Avatar
is there any possibility that you can point me to the correct page?
Old 05-19-2012, 10:53 PM
Dirt Driver's Avatar
So? Low load isn't taxing the pump and those AFRs are lean to improve fuel economy. What exactly are "issues under boost?" What does the AFR do under boost with methanol injection?
Old 05-20-2012, 07:12 AM
slacker's Avatar
This is the one I just used on that build I posted , http://treperformance.com/i-133110-t...1993-1998.html THIS is the one i would recommend + it's on sale
digitalracer
05-16-2016 03:57 AM
93toyoguy
08-02-2015 07:41 PM
anniesball
07-29-2015 11:46 AM
mengquis
07-13-2015 10:39 AM
Cplmike
07-08-2015 08:47 PM
Quick Reply: supercharged 3.4 in 3rd gen
