Such thing as Heavy-Duty Clutch Master Cylinder?
Old 12-15-2014, 04:41 AM
  #41
oldmansimek's Avatar
You might want to start your own thread. However have you measured your throw on the slave cylinder? Also did you buy aisin clutch master and slave (makes a huge difference) I had a similar problem on a friends truck, turned out to be flywheel after having resurfaced plus add in the missing material from 200,000 plus miles and a heavy duty clutch, slave just didnt have the reach.
Old 12-16-2014, 06:55 AM
  #42
Dalrus's Avatar
thanks for the information. Be a couple days before I can jump back into this project. I'll definitely re post either way. I'll re check all the advised causes. Thanks again
jasonty
41
12-23-2018 01:00 PM
mskalmus
05-28-2017 07:51 AM
09-04-2015 09:27 AM
HookahRoo
07-20-2015 07:06 PM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: Such thing as Heavy-Duty Clutch Master Cylinder?
