Such thing as Heavy-Duty Clutch Master Cylinder?
Old 07-17-2012, 11:32 AM
Toreador's Avatar
yeah, that.
So I bled it with a buddy, and nothing. Then I did the gravity bleed, and nothing.
Also, do I have to bleed the system after I adjust the clutch free play (by way of master cylinder adjustment rod)? Or can I adjust the pedal after bleeding and not worry about bleeding it after?
Old 07-17-2012, 11:43 AM
jerry507's Avatar
Ok, this is what I am understanding:
1. You've bled the clutch system.
2. With the bleeder valve OPEN you can push the pedal "to the floor" or at least a substantial distance.
3. With the bleeder valve CLOSED, you can hardly push the pedal in very far. Certainly not far enough to hit the start switch.
With the bleeder valve CLOSED, engine off, you under the truck looking at the slave cylinder and your buddy depressing the clutch pedal as far as it can go, do you see the slave cylinder extending at all? It's easiest to be watching before he starts the stroke to tell if there is relative movement.
Old 07-17-2012, 11:53 AM
Toreador's Avatar
Yes, all of that is correct.
As for the slave cylinder, it does not extend very much. It actually seems like it is not extending as much as it should.
I think I have a bent clutch fork.
Old 07-17-2012, 12:02 PM
jerry507's Avatar
When the system is fully relaxed, clutch pedal not depressed and cylinder all the way retracted, the fork should roughly be pointing straight out of the clutch housing, parallel to the front of the vehicle. There should be about an inch, maybe 1.5, between the metal part of the release cylinder and the fork. That should extend to say, 3 inches?, when the clutch cylinder is fully extended. It's a very noticeable increase!
Old 07-17-2012, 12:30 PM
  #25
Toreador's Avatar
Everything sucks
Old 07-17-2012, 12:32 PM
  #26
jerry507's Avatar
I get the feeling this is a problem that would be really obvious if you could look at two trucks side by side. Something is mechanically out of place on your truck OR your clutch system isn't bled enough.
Old 07-17-2012, 01:31 PM
  #27
drew303's Avatar
Your hydraulics are fine. Your problem is with the pedal. Its been broken once and "fixed"... my my best guess is its not fixed.
Old 07-17-2012, 02:52 PM
  #28
art
art's Avatar
I had a similar problem and it was the bracket. Look at the bracket when the pedal is pushed. It should not move at all. Maybe it was welded wrong.
Old 07-17-2012, 07:16 PM
  #29
Toreador's Avatar
It may be the pedal. But wouldn't the problem have started as soon as the 'repaired' braket went in? Or the problem just got worse over time? Either way, I'm going to check that before I drop the transmission and my truck is out of commission for 2 months.
Old 07-20-2012, 01:16 PM
  #30
Toreador's Avatar
Got a Video. Can you point it out?
Let me know what you see wrong in any of this video.
1st Clip: Pedal bracket flex-- will not reach ignition switch
2nd Clip: Why is it wet around that electrical connection?
and is there something abnormal about this wobbly clutch fork?
3rd Clip: Something is on backwards or missing, I feel
Thanks so much
Old 07-20-2012, 01:18 PM
  #31
jerry507's Avatar
I don't see the video...
Old 07-20-2012, 01:19 PM
  #32
Toreador's Avatar
Thanks so much
http://youtu.be/lAZI3KwYLWw
  #33
Toreador's Avatar
Woops
Old 07-20-2012, 05:25 PM
  #34
Toreador's Avatar
So what do you guys think?
Old 07-20-2012, 05:42 PM
  #35
jerry507's Avatar
I'm hanging out with my wife now, but I'll go down and double check on my truck tonight and reply. Initially though it looks reallllllllllllllllllllly strange to have that much fork play.
Old 07-20-2012, 06:35 PM
  #36
Toreador's Avatar
Thanks man, I appreciate it.
Did you also notice the flex in the pedal bracket-- the way the ignition switch moves away from the pedal?
And let me know if you have ideas on that fluid leak.
Old 07-20-2012, 06:36 PM
  #37
Toreador's Avatar
I'm a noob at this but I love my truck
Old 12-13-2014, 10:15 PM
  #38
Dalrus's Avatar
I realize this is a very old thread, but what was your final diagnosis or outcome. Im having very similar symptoms with the same LUK clutch in an 89 runner. Maybe you can shine some light on my issue for me.
Old 12-14-2014, 05:38 AM
  #39
wyoming9's Avatar
Red face
I doubt he ever came back if so not for quite a while.
So are you using fluid more then normal wear (very little)
Have you checked for a broken clutch pedal bracket ??
Clutch Fork starting to break or all ready broke??
Rubber hose old and starting to balloon under pressure??
How many miles on the clutch depending on use I have seen them fail at 20,000 miles or one day or go a 1/4 million miles only to be changed because the engine came out.
Old 12-14-2014, 11:42 AM
  #40
Dalrus's Avatar
First off thanks for the response Wyoming9. Ive always enjoyed reading everyones input I'm new to this so hope I follow the proper procedures. I'll try to give a brief history of my problem. 89Runner-3.0L Replaced clutch solely because engagement was at the top of the pedal stroke (340,000km original clutch) Actually had about .020" of material before rivets remaining. LUK gold performance kit replacement. Resurfaced stepped flywheel .008 All went well no issues. Installed existing slave no issues prior. Hydraulic system was not oopened up. Now, clutch pedal must be fully depressed before disengagement, that is right to the floor boards. Can go into R and 1st but right at the end of pedal stroke. Checked slave stroke .500", bled system no change. replaced CMC and slave cylinder, bled and re-bled still .500 stroke ( I am assuming is sufficient). Eliminated all free play at pedal and gained about .060" in stroke. Depressed slave cylinder all the way into the bore, clamped then pressed on pedal, rock hard (should indicate no air) Inspected pedal bracket for deflection and appeared to be nil, Hydraulic hose section had no obvious bulging on application, however when you wrap your hand around it you can feel a slight pressure build ie. movement. No leaks. Removed tranny. Inspected all hard parts and all appeared to be 100% No obvious signs of cracks in fork, Transmission input shaft retainer was smooth no ridge for throw out bearing to catch. Not sure if the hydraulic system can handle the increased application pressure that the HD pressure plate has. I'm guessing that the system must build more pressure on the diaphram to disengage the clutch. I'm open to all opinions/ideas all will be appreciated. Also.....is this where I should be putting my Q's lol.
Quick Reply: Such thing as Heavy-Duty Clutch Master Cylinder?
