Stuck in 4-low
Old 12-21-2008, 07:57 PM
scuba's Avatar
Originally Posted by small town BIG TOYS
This is the first I herd a auto had a clutch.
Well i was still unsure if it had an auto or stick...
Old 12-21-2008, 07:59 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
There was a thread started a few weeks ago, started by Tofer. I don't remember the thread name, but he was having trouble with his A340H auto tranny. Search for all threads by Tofer and you'll find it. I don't remember if resolved his issues, but I seem to remember they sounded very similar to yours....
But 1st things 1st......check your fluid level 2mro. Remember to get an accurate reading Let the engine warm up, and check the level of fluid while the truck is running
Old 12-21-2008, 08:16 PM
95RunnerSR5's Avatar
my buddy and myself have had this problem with only being to move in 4lo with the neutral like rev in 2hi and its an easy fix.. while driving forward in 4lo, shift to 4hi and then 2hi one at a time. for some reason or another both our 4runners came out of 4lo and went back to working like a clock.
Old 12-22-2008, 04:35 AM
the_ocho's Avatar
autos have clutches. lots of them. its just that they are all in packs for the different gears in the tranny lol.
Old 12-22-2008, 05:50 AM
  #25
scuba's Avatar
hah, I knew they had some sort of clutches inside...
But like I said...I didnt know if we were talking auto/manual....
Old 12-22-2008, 08:31 AM
  #26
before you flush the trans, try what i told you a few times and get back to me on whether it worked. cause like i said i know 2 4runners with auto trannys this happened to and that fixed it
Old 12-22-2008, 02:46 PM
  #27
small town BIG TOYS's Avatar
Lol it says it's a auto in the first post.
Old 12-22-2008, 05:13 PM
  #28
scuba's Avatar
Guess I read it too fast
Old 12-22-2008, 06:17 PM
  #29
I am just messing with you.
Old 12-22-2008, 07:33 PM
  #30
77celi's Avatar
I will try that tomorrow.
The fluids are full needs to be changed, I'll go in and have a flush and filter change. As soon as this thing moves out of 4low.
Thanks for all the help. Car forums are the best. I built my 77 celica from the info on classic-celica I put a 7mge in it.
Old 12-22-2008, 08:01 PM
  #31
the_ocho's Avatar
and now your name makes sense
Old 12-23-2008, 06:23 PM
  #32
77celi's Avatar
Ok I tried driving about 15mph and puttin it into 4H it's like it goes into N engine revs no engage. then I went into 2h and still nothing I even tried It in reverse.
I think I should get a rebuilt tranny and t-case. Anyone use one from japan?
Old 12-23-2008, 07:19 PM
  #33
Spence1016's Avatar
do you have to have it in park to go from 4lo to 4hi/2hi
Old 12-23-2008, 09:15 PM
  #34
77celi's Avatar
Yes I have tried that. I found a rebuit tranny that I'm going to get.
Old 12-23-2008, 09:37 PM
  #35
consult a tranny shop first. may be the torque converter going out.
Old 11-28-2017, 05:34 AM
  #36
HaynKing's Avatar
hey I have this problem also and do I shift while driving like just slam it into hi4 then hi2 without going into neutral? Please lmk
The following users liked this post:
Cuppcake3 (03-13-2023)
Old 03-13-2023, 07:33 PM
  #37
Cuppcake3's Avatar
Also struggling with this issue
Is there any new information or suggestions available?
Old 03-14-2023, 12:15 PM
  #38
Genera_lee's Avatar
The above recommendations are still solid, troubleshoot generally in least-to-most invasive order, checking off things as you go. not 100% sure on how the chain-driven t-case shifting functioned, but it sounds more like a trans, and less like a t-case issue above. not sure what your particular case is cupcake, but the FSM is a great place to start and has troubleshooting workflows for lots of major component systems you can leverage. also holy thread revival
Redeth005
06-28-2018 08:16 PM
rubrsidedwn
07-07-2016 07:28 PM
spiewaker
12-16-2015 01:10 PM
BK2TFUTURE
10-11-2015 08:42 PM
Obmi
09-24-2015 08:10 AM
Quick Reply: Stuck in 4-low
