Steering, susp. and brake upgrade 93 4runner...
Old 02-09-2011, 10:48 AM
jeffe's Avatar
I ordered parts to replace my idler arm, tie rod ends, brake rotors and pads, stainless brake lines, shocks and springs, urethane bumpstops and a kit for the front, torsion bars, steering stabilizer. Everything should be here by Friday.
I was going to have the work done in a shop. But I work as a contractor for Verizon and we have been on a freeze for ten days. So I have some free time to do it myself now.
I'm headed to Harbor Freight to pick up a few things.
Should I replace anything else while I have this all apart?
Here are a few pics....
Old 02-10-2011, 07:01 PM
jeffe's Avatar
More pics....
Old 02-10-2011, 07:09 PM
RMA
RMA's Avatar
what are you going to use the brass knuckles for ?
and what torsion bars are those ?
Old 02-10-2011, 07:15 PM
mightymouse's Avatar
if you're ready to replace the rotors are you sure you know what is involved? Re packing the bearings, setting the pre-load, 54mm socket, so on and so forth? Just making sure you don't get in over your head. Start researching the things i mentioned now instead of running into them later without any idea of what you're dealing with. i looked at your tool pic and if i'm not mistaken get a puller, or pickle fork the remove the tie rods and idler arm and use anti seize when installing tie rods. also if the hubs on your toyota are manual look into the cone washers as well. I can't tell but it looks like you have torsion bars to install as well. Might look into them and their hardware as well. This isn't to be harsh just from experience. Good luck.
Old 02-10-2011, 09:05 PM
jeffe's Avatar
Yea I already scratched the rotors for another day. I'm trying to get the tie rods, idler arm, and new steering stabilizer on tonight. I'm gonna wait until I get some manual hubs to do the rest....
jeffe's Avatar
trouble....
Old 02-10-2011, 09:35 PM
JonnyBoy's Avatar
A new cv boot on the passenger side outer should be on the list, too. Looks like it's torn at the first "valley" of the bellows from the outside.
Old 02-10-2011, 09:47 PM
jeffe's Avatar
Yea I saw that. I'm gonna order both the boots and change it out when i do the brakes. The Torsion bars are Sway a Way. I got them from Northwest Offroad...
Old 02-10-2011, 09:58 PM
JonnyBoy's Avatar
Good deal. Only thing I would add that I didn't think about for my last post is ball joint spacers. Helped the front work better at keeping both tires on the ground off road.
Old 02-10-2011, 11:23 PM
jeffe's Avatar
What do the spacers do?
Old 02-10-2011, 11:33 PM
JonnyBoy's Avatar
Puts another 1 1/2" between your upper a-arms and your upper balljoints. The torsion bars are connected to the upper a-arms, so it's a couple inches of lift without making the ride any stiffer. It's really no harder on your steering components than cranking your torsions. The only thing it could be harder on is your cv joints. I had to shim my droop stop a little bit to keep my cv's from binding at full droop, but I'm thinking of lowering the diff some now.
http://sdori.com/SDORI_Products.html
Old 02-11-2011, 12:18 AM
jeffe's Avatar
I'm not trying to lift it too much, I just carry alot of gear in my truck for work so trying to beef it up a little.....
Old 02-11-2011, 01:30 PM
jeffe's Avatar
Got the front steering together. Waiting for my girl to give me a hand getting the torsion bars in place.
Front shocks are in I'll add pics later...
Old 02-13-2011, 11:16 PM
jeffe's Avatar
I was able to get everything installed. Here are some pics...
Old 05-22-2013, 01:47 AM
T4Rguy's Avatar
Don't forget to change the blinker fluid!
Old 05-22-2013, 08:36 AM
jeffe's Avatar
Used the heavyweight so it would keep 'em blinking smoother!!
Old 05-22-2013, 02:46 PM
anthony1's Avatar
Did you know about the steering recall? Some of that stuff, including alignment, are free as part of the recall.
06-01-2021 01:51 PM
priest16
15
08-06-2015 07:43 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
bobpat
08-01-2015 09:25 PM
terminator
07-27-2015 07:13 PM
Quick Reply: Steering, susp. and brake upgrade 93 4runner...
