Starter quit workin' - contacts are good?
Old 05-12-2006, 10:16 AM
Asha'man's Avatar
My starter took a crap on Monday, leaving me temporarily stranded until I could get help to rollstart it. I've searched and read the writeup on 4Crawler on the copper contacts inside the starter. Pulled my starter yesterday (took maybe 30 mins, not as bad as I thought it would be) and popped the cap off. The contacts hardly look worn. I'm gonna swing by Carquest for SVO parts and have them test the starter while I'm in there. Shouldn't the contacts display a lot of wear if they're the culprit?
Brian
Old 05-14-2006, 11:45 AM
colsoncj's Avatar
One thing to note, and I feel stupid for tellin on myself, I thought my starter took a crap on me, replaced it with another good one I had layin around, 2 days later the problem came back... come to find out, it was a loose connection from the starter wire to the terminal (not the terminal to the battery)...
Hope you get it figured out, and yes, I would think contacts would show wear if they were worn out, I know alternator ones do, but I'm not 100% positive on starters.
Old 05-14-2006, 01:05 PM
Asha'man's Avatar
The starter tested good at Carquest, so I'm confident that it's still good. I stuck my meter on the little wire that comes off the starter and I believe runs to the ignition switch, and when "cranking" it got 3.5 volts. This seems inadequate to me, so I'm replacing the ignition switch this afternoon. If that doesn't fix it, I guess I'll have to go through all the cables and wires.
Brian
Old 05-14-2006, 09:07 PM
SoCal4Running's Avatar
Make sure it is grounded cleanly to the block/trans. More often than not this will make the starter "klick" when your contacts seem and are ok. You cant mount a starter to dirt/grease and have a complete circuit.
Old 05-15-2006, 08:27 PM
Asha'man's Avatar
That's definitely something to try. I replaced the ignition switch and that didn't do a thing, so I'm kind of at a loss right now. My dad said he had a starter from my mom's old '92 Camry test good at the parts store, but it just wouldn't work on the car. Bought a new starter and it worked great. So, I dunno. I'll try the cleaning thing.
Brian
Old 05-16-2006, 06:13 AM
jake the ssnake's Avatar
I replaced the ground and main 12v wires now it starts better than ever
https://www.yotatech.com/forums/show...arter+contacts
Old 05-21-2006, 07:13 PM
Asha'man's Avatar
Turned out to be the positive battery cable. :pat:
Brian
Old 05-21-2006, 08:40 PM
colsoncj's Avatar
good to hear you got it fixed!
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
thefishguy77
07-30-2015 10:59 AM
ZONAYODA
07-13-2015 07:17 PM
msane99
07-11-2015 08:08 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: Starter quit workin' - contacts are good?
