Old 02-09-2016, 10:13 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
SR5 Gauge Cluster Swap - How-to, with pics!
Old 05-27-2009, 02:17 PM
  #41
Junkers88's Avatar
Damn Bleeder you got more air time from this thread than Paris Hilton did from her......um...... video thread thing....... or something.
How's it feel to help out this many people? I'll bet you feel even better when you get off the computer and finish that motor.
Great job and nice write up man, we need to get this thing stickied.
edit: Just so folks don't think I'm just talking trash I used this write up to do the SR5 swap into my 89 DLX. It made things easy peasy.
Old 05-27-2009, 04:12 PM
  #42
iamsuperbleeder's Avatar
thank you very much Junk!
that means a lot, for real
that's why I made the thread; every week there was another thread asking about the swap, so I figured I'd try to help out as good as I could
oh and yes, I'm ready for my motor to be DONE already
Old 07-18-2009, 10:37 PM
  #43
mrddk92's Avatar
I'm about to do this but I think first I'm going to swap in some blue leds. Hopefully the tach works because that's the main reason I'm doing this. The cluster is from a 94 v6 runner so it should be all good.
Old 08-26-2009, 07:10 PM
  #44
mikelusk1's Avatar
what screw needs to be bumped to calibrate it. im using a 6 cyl sr5 cluster for a 22re dlx?
Old 08-26-2009, 08:52 PM
  #45
ozziesironmanoffroad's Avatar
bleeders gonna go look for the paris video..... lol.
great writeup man, im gonna have to use that when i decide to fix my odometer.
though, when i got the new oil sender for my swap.... i hooked it up to the outside one.... not the middle one.... pressure went slowly all the way up, then stayed there. think i fried it?
Old 08-27-2009, 01:52 PM
  #46
mrddk92's Avatar
I believe its. In the top right corner when looking at the back. Its a white thing with a phillips slot on the side. I think that's the screw but I have no idea which direction or how much a bump is lol[GVIDEO][/GVIDEO]
Old 11-03-2009, 09:05 AM
  #47
minimudder's Avatar
I just wanted to thank you for the great write-up.
Old 11-03-2009, 02:32 PM
  #48
no problem!
you are very welcome!
Old 11-15-2009, 09:00 AM
  #49
sickcrewcab's Avatar
Originally Posted by iamsuperbleeder
now you might have noticed the little bushing on the end of the pin that the needle pushes onto:
but with a pair of needle-nose vise grips, and some working back and forth, it comes right off, and leaves a bare shaft, wich is ironically exactly what the SR5 cluster's needle uses
and for a moment, I though this was goint to work out great
untill I went to push the needle on... and it wouldn't stay at 0...
A little trick I learned swapping my cluster yesterday. If you are interested in swapping your old odometer. When you pull the little bushing off shown in the first pic, turn it in a counter clockwise direction only. That keeps the odometer against the stop at 0. If you rock it back and forth it will stretch the spring. Great write up.
Old 11-28-2009, 10:47 AM
  #50
dwnhiller93's Avatar
i just did the swap today.. the rpm is off though. It came out of a 3.0 4runner, and I have the 22re. How do you get the rpm gauge to work for a 4cyl?
Old 11-28-2009, 10:54 AM
  #51
HAI-TEK7's Avatar
Theres a potentiometer on the back of the tach. You will another tach to calibrate it, but all you do is, adjust that screw. When i did mine i just bumped so slightly.
Hope that helps
Hai H
Old 11-28-2009, 11:52 AM
  #52
Hope that helps
Hai H
Thanks! I will try adjusting it.
Old 12-11-2009, 10:39 PM
  #53
UpTheYotaPunx's Avatar
this is awsome, and way easier than I'd imagined, now I'm inspired to do the same!
Old 12-19-2009, 09:24 AM
  #54
89whitetoyota's Avatar
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
The sencor you want to replace your old sencor with will cost about 5 times more, but you'll need it in order to make your oil pressure gauge read:
The original plug-in will still work though. Instead of plugging straight onto the sendor, the plug-in just slides onto the new sendor's tab with no modifications
Super where did you aquire this sensor, Autochevy, O'reillys and Advanced Auto only have the sending unit for the dummy gauge....
Old 12-19-2009, 10:20 AM
  #55
HAI-TEK7's Avatar
^ i got mine at Advance auto parts, it had to be ordered, took 1 day. You have to tell them its an SR5 model.
Old 12-19-2009, 10:59 AM
  #56
yep, that's where I got mine from, Advace Auto Parts, and yah mine took a day to come in too
BWD part number S4046, or Beck/Arnley part number 201-1130
Old 12-21-2009, 01:52 PM
  #57
Windsor's Avatar
Pep Boys had them in stock (when I did the cutover), fwiw.
Old 12-21-2009, 06:48 PM
  #58
davo247d's Avatar
so i was in proses of switching my oil pres sensers and how did u get the idiot light sensor out?
Old 12-21-2009, 07:53 PM
  #59
it just unscrews from the block with a wrench of coarse
Old 12-21-2009, 08:33 PM
  #60
briholt's Avatar
dash lights
nice work and write up!
how many dash light bulbs are there? Are they all the same kind? My CEL is out, and your point about redoing them all is a great idea, so when I crack this sucka open I'd like to know how many dash lights I'll be changing. Is there a little kit?
Quick Reply: SR5 Gauge Cluster Swap - How-to, with pics!
