Sputtering engine at high speeds. Any ideas?
Old 07-29-2008, 04:32 AM
1987tanyota's Avatar
My 87 yota PU stock 2wd has been acting funny lately... I drive roughly 75 miles average a day. lately after 27 to 30 miles holding at 65 to 70 mph the entire way it starts to sputter and acts like she's going to die untill the speed drops the 55 to 60 mph? My thoughts were fuel filter and maybe the fuel pump and Ideas?
Just trying to collect some second opinions... so feel free.
Old 07-29-2008, 04:42 AM
TNRabbit's Avatar
Timing chain slipped a tooth? Any funny sounds at idle? Check for codes before you do anything else...
Old 07-29-2008, 04:44 AM
there is a valve rattle at idle that I need to get corrected. other than that there is nothing major
Old 07-29-2008, 05:05 AM
TNRabbit's Avatar
Which engine?
Old 07-29-2008, 05:19 AM
22r with about 180k miles on it....
Old 07-29-2008, 06:05 AM
well guys only an hour left at work here... any more ideas?
Old 07-29-2008, 07:08 AM
well 15 minutes till I see if I can get my truck the 23 miles home any other ideas?
Old 07-29-2008, 09:05 AM
TNRabbit's Avatar
Crud/water in your gas?
Old 07-29-2008, 09:06 AM
rowdy235's Avatar
i'd replace the fuel filter. Its relatively cheap and it will eliminate that from the list of what could be the problem.
Old 08-01-2008, 10:00 PM
well I did a couple of things after some thought. I checked my distributor. The rotor and cap were shot. The fuel filter after pulling it was horrendouly clogged. and just for good measure I did the plug re gap and wires. So after all of the replaced and refilling the gas with seafoam added ... VICTORY. Her Gas milage is back up shes running like a champ and her power at the low end is back.
Charecter1
11-06-2023 10:08 AM
MTLroadierunner
07-15-2015 12:58 PM
Gamble_STi
07-07-2015 07:54 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Sputtering engine at high speeds. Any ideas?
