Speed sensor (1994 toyota pickup 4x4 22re)
Hey every body
I am not mechanically inclined at all..I am learning...my speedometer went out...(not registering the speed) I dont see any cable running from the transmission so i can only guess its a speed sensor or something...I actually see two sensor type things attached to the transmission...can somebody tell me which one regulates the speedometer? lol...lh side ...rh side?????
Right side, on the Transfer case (so it is measuring the speed whether you are in 4Hi or 4Lo.) VSS2 is in the transmission.
The part is not cheap, so confirm that 1) the odometer doesn't work either, and 2) Cruise Control doesn't work. Then it's almost certainly VSS1.
http://www.toyotapartszone.com/oem/t...181-35050.html
Thanks Scope
Its def not working in any gear configuration...this truck has no cruise control installed...The speedometer hasnt functioned in over 4 years...I use this truck for hunting trips. Thank you very much for replying
It doesn't appear so, judging by the bottom of the webpage.
Peteyg39@hotmail.com
06-26-2015 08:15 AM
Crazy_Guy97
12
06-24-2015 04:02 PM
