Spare Tire Removal
Old 11-14-2006, 02:53 PM
894Runner's Avatar
Spare Tire Removal
I apologize in advance for the simplicity of this question.......I have an '89 4Runner & want to remove the spare tire from underneath the back end. I have the "long hook" used to unwind it. Is there any "special procedure" I should be aware of before trying this? Thanks!
Old 11-14-2006, 02:56 PM
04 Rocko Taco's Avatar
slide hook through hole above bumper, attach hook to loop on tire "lowerer" (for lack of better word) spin hook. lower tire. IMPORTANT! spin hook in opposite direction to raise tire cable back up to correct position. replace hook...wherever it came from in a 4 runner.
Old 11-14-2006, 03:36 PM
4runnerx3's Avatar
owners manual
Old 11-14-2006, 03:59 PM
Elton's Avatar
yep very simple unless you dont have the hook i learned the hard way
Old 11-14-2006, 09:24 PM
bikeguy18974's Avatar
Also a good chance its rusted to hell and you'll need to soak it in some penetrating lube to get it to move.
Old 11-14-2006, 09:26 PM
Elton's Avatar
pretty sure its been a few years since mines been used ill have to try it 2morrow
Old 11-14-2006, 09:58 PM
CJM
CJM's Avatar
For a truck in a snow area I findit funny mine came right off with ease.
Old 11-15-2006, 05:34 AM
894Runner's Avatar
Thanks guys; the tire came out with ease! The pic from the owner's manual was spot on......
Speaking of the owner's manual - anyone have an electronic copy for the 1st Gen 4Runner - or know where to find one?
Old 07-08-2008, 05:43 PM
zenchef's Avatar
No Handle??? Use a 12 MM Wrench
Originally Posted by 4runnerx3
owners manual
Hi, Guys.
Thanks for the rad forum. I've used it so far to figure out how to remove a pinion seal and now my spare. In case you don't have the handle for the "S" bar, use a 12mm wrench at the end and a cheater bar. It worked like a charm for me for both breaking the tire free and for the jack.
Peace
Old 07-08-2008, 05:53 PM
EWAYota's Avatar
I lowered mine......then took it off.
Old 07-22-2008, 01:30 PM
awareness's Avatar
When I bought my truck it was missing this bar, apparently searching junk yards might be futile as well as it is a common missing part. Is it easy to fab one of these up?
Old 09-11-2008, 11:07 AM
934rnr's Avatar
Alas I tried to move mine to no avail. I think I will end up cutting mine out of there to remove the spare....
Old 09-13-2008, 12:07 PM
Hypoid's Avatar
It's a cute little harmonic device, neat to see how it works.
Mine was cute enough to have rusted enough to jam full and not possibly turn at all. I fabbed a huge wrench to turn the input and was about to start breaking things.
I managed to undo the two horizontal braces the tire tightens against, which let me swing the tire forward enough to get a pair of bolt cutters in there and cut the chain.
I've cleaned out the mechanism, and completely filled it with grease. It'll probably work great if I ever get around to putting back on.
Old 02-03-2014, 09:15 AM
feathergirl's Avatar
87 pickup spare tire tool-need another option
Hey there eveyone thanks for the site. I need to be able to get my spare tire off without the tool, cant find one and not spending 90$ on one....isn't there any other tool I can use? My mechanic used a big-ass screwdriver but I'm not buying one of those either- too expensive. What if anything has anybody used? I will be driving my baby across the country in a bit and want to be prepared. thanks in advance.
....tried to attach picture, did it work?
Old 02-03-2014, 09:32 AM
Fossilized
Staff
dropzone's Avatar
Go back to your mechanic and have him lower it and out the tire in the bed.
Old 02-03-2014, 09:45 AM
spare tire
I can do that but I am moving and need all the space I can get in the back, plus need to get to the tire if I get a flat. thanks but I'm looking for alternative cheaper version of the actual tool itself and to see if anyone had any luck with anything.
Old 02-03-2014, 10:39 AM
Fossilized
Staff
dropzone's Avatar
At some point you are going to need to spend $20 for something to lower the tire. The long screw driver is about the cheapest alternative to finding the j rod.
Old 02-03-2014, 12:23 PM
Nervo19's Avatar
Harbor Freight, $8.99 for two. You can get them mail order if you don't have a store nearby. Alternately you can post a wanted in the classifieds here for the Toyota tool.
http://www.harborfreight.com/2-piece...set-34253.html
Old 02-03-2014, 12:37 PM
spare tire tool
thanks to both of you, i didnt realize the long screwdriver would be that inexpensive, the flat head does need to be a bit bulkier than what is shown here but its gives me a good idea. thanks. love the forum. Just changed shocks and repacked wheel bearings for the long trip. My baby has been stolen and totaled but I keep getting her fixed and she keeps on tickin! thx!
Old 02-03-2014, 12:41 PM
mbomberz1's Avatar
Just get some steel rod, weld a flat piece of metal to the end that fits the slot the hook goes into, then put a Z bend into the handle side. It wouldnt collapse like the OEM one but i bet its cheap if you have any scrap metal
Quick Reply: Spare Tire Removal
