soldering up a Supra AFM
Old 02-22-2009, 09:07 AM
  #81
Matt16's Avatar
Did you take pics???
I messed around with my spare 22RE AFM that the PO pulled the plug-in out of and i couldn't get the circuit board out of it- the board was stuck between the housing and the armature (the bit connected to the flapper that moves).
Old 02-22-2009, 11:23 AM
  #82
BigBluePile's Avatar
I didn't take many pics 'cause there wasn't really anything to take pics of. I didn't swap any boards around and I'm not done with the intake any ways. I just put it together to see if it would work. The intake still runs the way it did before(OEM). I still need to pull the intake apart and rtv the connections.
Old 02-22-2009, 09:18 PM
  #83
Matt16's Avatar
Questions for Big Blue Pile:
What's the power like?
I saw those filters on Ebay I think, are they re-useable (can you clean them)?
Here's how I am planning on setting my AFM up:
Old 02-23-2009, 07:59 AM
  #84
I haven't had a great chance to take the truck out and see what it'll do. I need to double check the timing and maybe play with it a little. The road test I did do, I didn't really notice anything...
Yes, they come preoiled and you can get reoiler kits for them. That cone filter is almost twice the size of the K&N cone filter. It's Spectre brand and I bought they're couplers and flex tubing. They have different colors too, if that matters. I didn't need the couplers for this setup because the tubing had it's own connections. I did have to break off the factory mounts of the AFM to fit the filter though.
Old 02-23-2009, 04:15 PM
  #85
I though about running my intake that way but I was worried it might affect the spring and flapper door inside the AFM after while. Also, my RANCHO 9000 shock adjust pump sits right there.
Old 02-23-2009, 04:52 PM
  #86
Blackulua's Avatar
Here mine my on my white truck set-up
I ordered a silicone hose for the TB to leftover 3" exhaust pipe to stock 22re
3" I.D. hose connected to the modified Supra AFM.
Heres my other truck with a AFM left and battery moved to the right.
This AFM is the 82 Supra plug-in that I found at the junkyard untouched.
The hose is from a Dodge Dakota and the air filter is a Dakota Air Raid from my friend.
Both truck has the LCE Big Throttle Bore.One truck has the later type and the other has the early type.
Old 02-23-2009, 06:11 PM
  #87
I too am running the LCE Big Bore TB and I think to get the best benefit of the whole AFM swap I need to swap over the battery/intake. Your set up looks great! Thanks for the pics!
Old 02-23-2009, 07:00 PM
  #88
sas'd22re's Avatar
i tested my afm and found that one of the readings between E2-THA was out. would this one thing throw off the afm? im a rookie when it comes to multimeters and afm's and hope i am doing things right. i checked it twice and got the same readings
should be between my readings
E2-VS 20-400 105
E2-VC 100-300 180
E2-VB 200-400 280
E2-THA 4K-7K (around 5*celsius outside) 3100 (i think)
E1-FC infinite infinite (i think, multimeter
stayed at 1)
any help would be great.
Old 02-23-2009, 08:35 PM
  #89
E2-VS 20-400 105
E2-VC 100-300 180
E2-VB 200-400 280
stayed at 1)
Man I could SWEAR I've seen this post before...
Look here:
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
Old 02-26-2009, 12:50 PM
  #90
Matt16's Avatar
My Supra AFM came in the mail today, pics soon to come. Part number 22250-43110. I won't be installing it for a couple weeks though.
I like this set up here:
Old 02-26-2009, 01:50 PM
  #91
Junkers88's Avatar
I think mine is cuter. Or "It's stho sthparkley!!"
Yeah Matt you have the right part numbers there. Why wait on the install? It only takes a few minutes once you have all the parts.
Old 02-27-2009, 12:44 PM
  #92
ebow951's Avatar
Nice pics Logan! I absolutely agree about the throttle body; it would certainly help you achieve the maximum benefit from this upgrade. One day I'll be putting in my LCE order.
Old 02-27-2009, 01:31 PM
  #93
Matt16's Avatar
http://www.celica-gts.com/forums/ind...opic=7543&st=0
This would be cheaper and the Supra TB is actually larger than the LCE TB.
Old 02-27-2009, 01:39 PM
  #94
Matt16's Avatar
Still need the 90* bend, the welding cable to extent the battery leads and the air filter...
Old 02-27-2009, 01:40 PM
  #95
Yeah, I probably would have tried this if I'd have know. I had the money and an extra TB layin around. I think the LCE is a 59mm bore...
Old 02-27-2009, 01:43 PM
  #96
Where are you going to get your welding cable from?
Old 03-01-2009, 07:23 PM
  #97
ffryno13's Avatar
so i just got a 82 supra AFM what kind of electrical stuff did you guys have to do the swap. or is it straight plug and play? i have a 22re 4x4 1990. and i already have LCE intake but its still kinda restrictive.
Old 03-01-2009, 07:34 PM
  #98
It could be, I think the plug-n-play part number is in this thread somewhere...
Old 03-01-2009, 07:37 PM
  #99
ffryno13's Avatar
so do they all look the same or is there a difference in the style of 82 AFMs
Old 03-01-2009, 07:42 PM
  #100
https://www.yotatech.com/51067448-post82.html
Quick Reply: soldering up a Supra AFM
