soldering up a Supra AFM
#41
Matt finding one is hard enough, deciding if paying what the seller wants for it for the gains is even worse. I got unlucky in that the first one I found (wrong part number) was only 16$ but consider myself very lucky to have found one that was right for just under 70$. If you can wait for a few days I'll be able to go back to the yard and see if they have any more. Although I can't send you one for free I'll only charge you what they did (I'll send a copy of the vendors reciept along) plus whatever shipping will be.
That is if I can find more than one since I need one for the 4runner.
I'll keep you posted.
edit: I forgot to add that a new one from NAPA is almost 700$ so 150$ might not be too bad if it's all you can come up with and I can't find any down here.
#42
Spectre Air Filter
The Spectre cone filter Junker used is available in Langley from a place called TYA.
Langley 19889 Fraser Hwy. (East of 200th)
604-539-9577
You have to place an order and deposit, and then wait. I'm thinking of picking up this:
P4 Cone Filter Multi Fit Base Blue #8136
Black Ducting #8741
Blue Cuff x2 #87416
Info and catalogue at www.spectreperformance.com Let me know if anyone's going to place an order, so we can all get in on it and get the shipping faster.
#43
Matt, where in BC are you?
I just stopped into Lordco for something else and asked about the part. They wanted $450 new.
A guy wants $150 used? For that I'd just grab a '83-85.5 and do the mod. I'm gonna do this mod myself soon, so I'd lend a hand if your in the GVRD.
Hey Logan, check out one of my latest threads. I posted a few preview pics for you before I post the whole build.
#45
You can find the same AFM on alot of 5M-GE engines, thats were i got mine from, and the part numbers match those posted in the links above. 22250-43110 and 197100-3020, should be plug and play.
#46
I may have a line on a donor AFM from an 84, 85 or 90 (my choice).
Interesting read. http://www.geocities.com/MotorCity/lane/1231/afm.html
But, I;m a little confused. What exactly am I swapping between the AFMs? Just the circuit boards?? The internals of the Supra AFM and much bigger than the 22RE;
#50
In comparing the afm's it just looks ridiculous how different they are! I "hopefully" just scored an '82 supra afm from a junkyard out of CO for cheap, we'll see.
Matt,
I read that link you posted and it mention replacing the fuel injectors? Is this something we should be concidering as well? I don't remember reading that anywhere...
Matt,
#51
Matt,
Matt,
#52
I've sent off 20+ emails to people selling Supra parts seeing if I can find an '82 but it looks like Celica guys snap them up quick for their 22REs- which I think is plain selfish, their cars don't weight anything to start with.
Blackulua (sp?) has been a huge help so far, I'll post what I've learned tmr.
#53
#54
I think I've found an '82, no idea the price yet (offered $55), it is in the Eastern US (so shipping will be about $20) as long as the Supra AFM weighs less than 4 lbs packaged.
#56
I'm going to use an cone filter on mine till I figure out if I'm going to run a snorkle or not. I still have to swap the battery to the other side still.
#57
The toyota cressida which was mass produced has the same MAF in it as well. complete plug and play. I have a MAF out of a 1990 4 cam, way bigger throat, rectangular box so you can install a high flow filter. Do those swaps and i will guarantee you 10 to 15hp to the wheels .
#60
