Snow plow on a 2end gen???
the plan is by the time this has a plow on it, i have a newer DD. even tho the plow won't live on it so far this year it would have seen 3 maybe 4 plowings.
it will also be a lite tral rig once i have a dd
For me, I'd never waste my time and money on putting a plow on a mini truck. We have a 3/4 chevy diesel, and there are still times that that's not enough power/weight to push snow around our drive way, I can't even imagine how much a light, not torquey plow truck would piss me off.
My truck (pictured above) is stock as far as mods that would improve plowing). That plow is a 6'6", which I would consider smaller than full size, but larger than ATV.
#25
6 inch plow is pretty small. might take awhile to get the driveway plowed...
It's not really an issue of torque. you put it in 4low, 1st gear, and you have plenty of torque unless you're trying to plow 4' or something like that. I'd personally get a bunch of sandbags or some other weight for the rear end to help it dig in more for traction purposes, but other than that a 6' plow shouldn't be an issue
#27
#28
the plans are for a quick disconnect system
and the drive way is not that big
and only a half dozen or so uses a year
so the runner should be fine
kawazx636
10-06-2021 03:03 PM
Toys4parts
09-26-2015 01:56 PM
