slight vibration and humming
Old 05-13-2010, 05:04 PM
94toy22re's Avatar
between 25 and 60 i have a slight vibration and a humming noise. it stated right after my bj spacer and marlin crawler 6in shackle install. What could be causing the problem ,the u joint, do i need shim the axle to fix the rear pinion angle?
Old 05-13-2010, 05:14 PM
marsbike's Avatar
sounds like the carrier bearing in your front diff is starting to go... mine started that way. Now my feet go numb around 75... Just gotta find the time to replace my front diff...
That said, I could be completely wrong... YMMV
the_supernerd
10-01-2015 09:20 PM
hiluxinargentina
09-30-2015 05:51 PM
dbollier123
09-29-2015 05:23 PM
JPV
09-28-2015 03:15 PM
Odin
09-26-2015 06:56 PM
Quick Reply: slight vibration and humming
