Show off your swapped in seats!
Old 11-27-2011, 03:42 PM
  #61
yotarover's Avatar
it is adjustable just take out or add more washers and longer or shorter bolts.
Old 11-27-2011, 04:30 PM
  #62
ThatGuy1295's Avatar
Junkers88
Is that 2 door latch handles I see on the inside of your door?
Old 11-27-2011, 05:19 PM
  #63
yeahhhbuddy's Avatar
Wouldnt I need to bend the forward bracket downward if the rear mounts are elevated? If the rear mounts are bolting straight down, then surely the front brackets will be elevated too and would no longer be able to fit into the frame. Am I wrong?
Old 11-27-2011, 05:51 PM
  #64
Swimmerboy2112's Avatar
The first gen 4Runners have 2 latches, the one closer to the back is for the people sitting in the back so that they don't have to reach all the way up to the front handle to get out.
Old 11-27-2011, 06:21 PM
  #65
blakefogt's Avatar
i really appreciate this thread. I've been doing alot of research in finding a good repacement for my non sr5 1987 4runner's seats. So far it's looking like I gotta go find sr5 ones.. but keep this up.
Old 11-27-2011, 07:53 PM
  #66
Cool beans
Never new that
Old 11-27-2011, 09:29 PM
  #67
yotarover's Avatar
Originally Posted by yeahhhbuddy
Wouldn't I need to bend the forward bracket downward if the rear mounts are elevated? If the rear mounts are bolting straight down, then surely the front brackets will be elevated too and would no longer be able to fit into the frame. Am I wrong?
if your talking about the spacer/washer idea. raising the rear will actually level out the seat. after going so high just back the bolt out a lil in front. then retighten. or put a washer in front with a longer bolt.
Old 11-27-2011, 11:21 PM
  #68
Ok I did notice that it would level out the seat since the front is bolted on an elevation in the frame, not on the floor. Is 1" of height going to make much of a difference in height? Does anyone know if the seat without the 1" lift sits lower than the OEM bench seat or higher or about the same?
Old 11-28-2011, 09:38 AM
  #69
yotarover's Avatar
my full bench seat sits higher than the buckets. 4crawler makes seat risers i think. when i raised my 89 buckets i used 10 or more washers. then got the idea to find a large socket about 2-3" long. that way i could see a lil over the hood.
with the buckets in my 86 std cab i have to remove the head rest if i wanna raise them.
Old 11-28-2011, 09:44 AM
  #70
irab88's Avatar
shoot, didn't even remember to update:
all seats done, along with sr5 center console
Old 11-28-2011, 09:56 PM
  #71
2-3" sockets? Do you have a pic of what you are describing? I actually do want to remove the headrest as I never liked those things anyway. If the buckets sit lower than the bench, I definitely need to raise it 2-3"
Old 11-29-2011, 08:35 AM
  #72
yotarover's Avatar
haha look in your tool box. find the biggest tallest socket you have and put a snuggy bolt through it. tighten it down. i would take pics but i took those seats out and put them in my other truck. if you know how to machine or drill take some solid round stock and make a small lift that way.
Old 11-29-2011, 09:59 AM
  #73
Oh I see. A deep socket that can fit a bolt through it. Now wouldn't raising the seat on a 3" deep socket elevate the front brackets?
Old 11-29-2011, 10:38 AM
  #74
blakefogt's Avatar
got my hands on some '86 sr5 seats
Old 12-19-2011, 12:46 PM
  #75
Quagland's Avatar
Originally Posted by Swimmerboy2112
How did i miss this thread?
did those just bolt right in?
Old 12-22-2011, 08:02 AM
  #76
RCFJ40's Avatar
Does anyone know if you can switch bucket seats for a bench in a 1987?? Thats the opposite from what i have seen, but I have two kiddos i need to haul so id like to get a bench. Does anyone know if it is a plug and play??
Old 12-22-2011, 08:04 AM
  #77
irab88's Avatar
if not, it's pretty close
Old 12-22-2011, 08:16 AM
  #78
RCFJ40's Avatar
Great thank you.
Old 12-22-2011, 10:13 AM
  #79
muddy chevota's Avatar
no pictures but leather bucket seats out of a 96 chevy ext cab with all power options, put into place, and welded to the floor, you sit up off the floor a bit more but they sure are comforatable
Old 12-23-2011, 09:45 AM
  #80
93YotaGuy's Avatar
From a bench to 4runner seats and middle console in my 93 4x4
and the bench from my 93 to replace the old bench in the 91 2wd
Quick Reply: Show off your swapped in seats!
