Should I invest in a transmission oil cooler? Which one?
Old 03-27-2009, 08:39 AM
rustypigeon's Avatar
Hey guys. I have been thinking of getting a transmission cooler. I don't do any towing or demanding driving, but I am just getting paranoid about my radiator cooler springing a leak an dumping cooland into my tranny. My plan would be to bypass the radiator, and use only a separate transmission cooler.
How common of a problem is a radiator cooler leak? Do these happen often enought for me to worry about?
For those who have installed coolers, which one is the best?
ETA: This is a '94 Pickup A340F transmission
Old 03-27-2009, 09:10 AM
okie81's Avatar
TRD makes a good tranny cooler, fairly easy to install too. I don't do much towing either but it was a good investment.
https://www.yotatech.com/forums/f128...4runner-76336/
Old 03-27-2009, 09:49 AM
mt_goat's Avatar
Its much more common with the 96-04 trucks, not very common at all with the 86-95 trucks. What does that tell you about Toyota quality standards lately LOL.
If you bypass the rad cooler, go with a cooler that has a built-in bypass for cold ATF, like the TRU-COOL LPD ® LOW PRESSURE DROP OIL COOLERS. http://www.importperformancetrans.com/coolers.shtml
The TRD cooler (made by Hayden) doesn't have one that I've seen.
Much more info here:https://www.yotatech.com/forums/f2/b...cooler-126953/
smthwsn357
05-01-2024 07:28 AM
jjrbus
07-17-2015 07:06 AM
Poncho0206
07-10-2015 06:21 PM
Coreyr384
07-10-2015 11:13 AM
Snort
07-09-2015 03:58 PM
Quick Reply: Should I invest in a transmission oil cooler? Which one?
