Shorting the Timing check Connector
Old 01-27-2010, 03:50 PM
dwnhiller93's Avatar
So when setting the timing after doing the timing chain, it says to short the timing check connector to get a accurate reading. I found the plug, put an unbent paper clip in it.. And it didn't change anything. What are the proper steps to shorting it out? I think I am doing something wrong.
Old 01-27-2010, 04:13 PM
langzaiguy's Avatar
You want to jump Te to E1 if I remember right. Make sure it's a good connection. You'll hear the RPMs drop and see the engine light flash.
Old 01-27-2010, 06:07 PM
So I pull the plug of it while the engine is running?
Old 01-27-2010, 06:19 PM
Elton's Avatar
did this on my friends 85 it dropped the idle just a little u be amazed how far off it is when not jumped
PureTacoma_Tundra
PureTacoma_Tundra
07-02-2015 12:35 PM
jacksonpt
06-17-2002 09:47 AM
Quick Reply: Shorting the Timing check Connector
