Short shifter
There's one here.http://www.toyotacatalog.net/M1WebGe...spx?Class=1582
Here's some more.http://www.urdusa.com/index.php?cPath=106_73
One for the transfer case, if you were wonderin'.http://www.4crawler.com/4x4/ForSale/...wShifter.shtml
could try what i did on my 2wd stick. i just sectioned about an inch or so out of the top, narrower part. and another inch or so from the lower, wider area. then welded the 3 peices back together. part that sucks is mine was actually 2 peices with rubber between. probably need some epoxy between them to hold them back together after the rubber burns out...which it will.
its a shorter throw, and it is physically sorter. which i also wanted. the kits are usually stock height. i have some pics of it on my street source profile here:
http://www.streetsourcemag.com/viewo...rofileid=45650
sorry, it hasnt updated the photos yet. should be soon though.
Looks like this one will fit our trucks ( not sure about with a 4cy though)
http://www.toyotacatalog.net/M1WebGe...B-FF6F56AFDCF2
Yeah, I geuss that was a little much to ask people, to pick that one there out of the link I posted above. Thanks Jay351, it looks like I need all the help I can get on this one.
Oh, so you know the 22re or 3RZ are both 4cyl. And yes there's a short-throw stick for them, or any Toyota practically.
I believe they are. They look close to it from the pics. Check the urdusa.com link above. I think your supposed to use your stock stick with those. The piece that looks like a "pawn" would attach to the bottom of the OE shifter.
heh, I never heard of a 3rz
Im tehhh newb sauce
i went to the first link hippy, and i believe that short shifter would work with just about any yota in this forum. however, i couldnt stop there. just had to go and look at turbochargers. ugh. why dont i have money? lol
