sensor next to coolant temp sensor on 90 22re,what is it??
Old 01-28-2012, 03:31 PM
brino1's Avatar
i cant figure out what the sensor is that is to the left of the coolant temp sensor on my 90 22re.any ideas??
Old 01-28-2012, 04:41 PM
mldave's Avatar
Size:  70.3 KB if it's the one on the left it's the cold start injector time switch.
Old 01-28-2012, 05:19 PM
brino1's Avatar
that figures,its the one thats $150!!
Old 01-28-2012, 05:44 PM
mldave's Avatar
brino1,mines an 86 truck....probably different part # you can get them from a junkyard for $ 10-$ 25.
Old 01-28-2012, 05:59 PM
brino1's Avatar
ill prolly go hunt for one tomorrow
Old 01-28-2012, 06:38 PM
mldave's Avatar
You might have to have the same part number...think it's located on one of the flat surfaces.
Old 01-29-2012, 10:39 AM
abecedarian's Avatar
Why are you wondering about it?
Does the truck start up when cold?
Old 01-29-2012, 11:26 AM
brino1's Avatar
it starts,but only after cranking for about a min.starts fine when its warmed up or warm outside.the connector for that sensor is actually broke off.
Old 06-25-2012, 04:26 PM
stock93's Avatar
Sorry to dig up an old thread but I broke that black sensor off the other day. I pulled it out and it looked like a probe so I figured a coolant temp sensor. I was just wondering if you could tell me what you ended up replacing?
Old 06-25-2012, 10:47 PM
That sensor is called "Cold Start Injector Time Switch".
It's purpose is to complete the circuit that causes the cold start injector to squirt fuel while you're cranking the engine... IF the engine is cold, as in below around 65F degrees.
the1998sr5
15
07-14-2020 08:35 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Jeffreynmandy
07-18-2015 08:26 AM
Poncho0206
07-10-2015 06:21 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: sensor next to coolant temp sensor on 90 22re,what is it??
