Seat Swapping bench to buckets...
Old 05-23-2011, 11:32 PM
cman1's Avatar
Question Seat Swapping bench to buckets...
I have a bench seat in my 92 pickup dlx,is it feasable to swap out buckets and console from another pickup or runner from like 90 to 95?is it a bolt in deal.or modify?
Old 05-24-2011, 12:21 AM
Sportsmanphil's Avatar
Let me save the next guy from having to type this. There is a few hundred threds on this topic, one was just a few weeks ago. Search the topic and you will find a plenty of info on this including hundreds of photos.
Old 05-24-2011, 08:20 AM
atari56's Avatar
Seats Covered...console no
Seats are easy, search. Searching for an article on a stock SR5 console install...not too much help out there.
As soon as my carpet and Corbeau seats come in I will post a thread on my console install, until then search, a lot of people do the ammo can center consoles and they even remove the rear heater from the 4 Runners to get more storage space.
If you're serious about swapping in an SR5 console go used but get your hands an eyes on it
before you buy it. I wasted $70 on a used one, went to stealership an spent $430 on all the parts to install a brand new one, but to me, it was worth it.
Sorry for the rambling.
Old 05-24-2011, 10:07 AM
atari56's Avatar
430 for console between seats
Originally Posted by kris smith
$430.00???? Ouch. I want to do a SR5 cluster swap but can't find one except the stealership.
Maybe my bad, I dunno, I paid 430 for the center console that goes between the seats, the the dash console containing the tach and speedometer.
Another note, it is getting mighty hard to find bolt in used seats for this mod, that's why I went with corbeau. If I'm going to do it, might as well go all out.
Old 05-24-2011, 10:35 AM
SCToy's Avatar
With a little determination you can make just about any seats fit. I put these 85 MR2 buckets in my 95
Heads up on the corbeaus, if you're tall then you will most likely need to modify the bracket. When I got mine I had to cut the front legs down and redrill to fit inside the cab. Also had to cut the rear legs down and weld longer extensions on the bottom to reach to the holes. Whoever built the brackets never actually put a seat on it and got inside the truck, or they were really small. Love the seats though.
Old 05-24-2011, 10:58 AM
Outsane's Avatar
I have the same seats! nice work
Old 05-24-2011, 12:12 PM
atari56's Avatar
Thanks for the info on the corbeaus. Gives me another step in the interior redesign to look forward too.
Old 05-24-2011, 05:04 PM
cman1's Avatar
i guess i should of specified toyota 4runner seats to a 1992 toyota pickup single cab dlx.is it a bolt in for reletavely close years.
Old 05-24-2011, 05:30 PM
SCToy's Avatar
Yes the seats bolt right in, never had the console, but I swapped the mr2 seats because they are a lot nicer than 4runner seats IMO
Old 05-24-2011, 10:11 PM
cman1's Avatar
thanxs sctoy.
icentropy
09-16-2020 02:47 PM
jasonty
41
12-23-2018 01:00 PM
noahstancik
07-17-2015 05:38 PM
icentropy
07-09-2015 02:12 PM
garagespace
07-09-2015 08:37 AM
Quick Reply: Seat Swapping bench to buckets...
