Seal for steering column
Old 01-12-2020, 04:29 AM
old87yota's Avatar
Can you give a little more detail about your truck?
It sounds like you are working on a 2 Wheel Drive Truck with an automatic transmission and column shift.
Old 01-13-2020, 02:28 AM
Tman123's Avatar
Toyota pickup 1986
Originally Posted by Tman123
I need to replace upper shifter bushing
on steering column. The only way I see
to do it is slide steering column up 1” to
get bushing in housing. I looked for the top steering column shaft joint. I removed the cover in the floor board but it will only raise up about 3”. I can’t
see A joint from inside the cab or under the hood except the one connecting to the power steering gear box. I removed the bolt that holds the joint to the steering gear but when I try to slide the
steering column up a little in the cab I can’t get it to budge. Should I pry on the joint at the gear box to get it to slide. I really need some help with this. If there is an upper joint connecting
intermediate shaft to top shaft I can not find it. It must be directly in middle of
firewall if it exists. Any suggestions
or help would be greatly appreciated.
Tman123
I want to add that my truck is a 1986
Toyota pickup with auto transmission, 2 WD, 2 BBL carb, 22R
engine, 1/2 ton shifter is on steering column. I really need help. All the diagrams have parts of the steering column but none of them are completely accurate. Does this column have an intermediate shaft and bottom shaft entering steering gear box? How does it come apart??All I need to do is replace the upper shifter bushing. How is this done? Steering column has to be raised 1” shifter lowered 1” or shifter switch
housing pulled off steering housing
but cannot find diagram or procedure to pull this. Can anyone
help? Tman123
DericK.
12-26-2020 05:39 PM
jasonty
41
12-23-2018 01:00 PM
Jcrawl94
10
10-24-2015 04:34 PM
swerks
08-23-2015 06:32 AM
RBK
08-02-2015 11:33 AM
Quick Reply: Seal for steering column
