Running rough, wont rev?
Old 11-29-2010, 05:25 PM
95blackToy's Avatar
Exclamation Running rough, wont rev?
Alright here is the problem, the other day i was driving back from Louisiana going about 70, well i ended up having to slow way down due to traffic. As traffic picked up again i gave it some gas and it felt like i was out of gas, misfiring or in to high of a gear, so i downshifted to second and it did the same thing. Well it all of a sudden fixed itself and i carried on. I got home and checked my oil as i have a drip and can smell it when the motor is under a load, it was low so i filled it.
Today drove a few miles and parked it for probable 20 minutes went back out to go somewhere and it idled at about 500. I ignored it until i went to go and it wouldn't go. seemed like it was misfiring or the timing was way off. so i tried revving and it would barely respond and i could only get it to rev up to 2000 RPMs even when flooring it. So i started to drive to see if it would resolve itself and sure enough it did. It was jerking slightly in first and would only rev to 2000 so i shifted and heard a pop and it then picked up and ran like normal.
Any ideas. I also set the timing to 12 a few weeks ago and it did good up till the past to incidents.
sorry for the long post but i wanted to include the whole story. And by the way its the 3.0
Old 11-29-2010, 05:36 PM
95blackToy's Avatar
No one has any input?
Old 11-29-2010, 06:15 PM
rworegon's Avatar
How do the spark plugs look? The oil? Coolant?
Old 11-29-2010, 06:24 PM
95blackToy's Avatar
no check engine light plugs are fairly new only about 7k miles on them since i did the head gasket, same with coolant, its full. new cap and rotor. didn't give it new wires but they are also kinda new.
Old 11-29-2010, 06:30 PM
rworegon's Avatar
IMO, while the plugs are relatively new, take a look at them anyhow..they just may have a story to tell.
Old 11-29-2010, 06:34 PM
95blackToy's Avatar
I will try to pull them out tomorrow, and take a look. I'll post up and let yall know. Thanks in advance. What should I be looking for on them. Since its not a constant problem it will have to be some permanent damage to them or something right?
Old 11-29-2010, 06:51 PM
rworegon's Avatar
Check for loose or corroded grounds too....
Old 11-29-2010, 07:20 PM
95blackToy's Avatar
Sounds like a plan. I'll try and let y'all know tomorrow
Sleaker
08-26-2020 06:03 AM
09-04-2015 09:27 AM
v_man
07-23-2015 04:01 PM
Jnkml
07-06-2015 01:20 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Running rough, wont rev?
