Rubbing noise up front when turning cold
Old 12-05-2011, 09:00 AM
vision19's Avatar
Hey all,
First I want to say that I did search for an answer but did not find much in way of an answer. I've got a 93 pickup 4x4. Now that the weather is cold (under 20 degrees) I get a rubbing noise coming from my front suspension (or steering?) when I turn partially - not full lock. The noise actually goes away when I turn to full lock. This only happens until the truck is fully warmed up. The power steering fluid is at a sufficient level and was flushed and replaced a couple months ago. Anyone have any insight?
Thanks
http://youtu.be/w62H0scnEJU
Old 12-06-2011, 09:24 AM
vision19's Avatar
So after driving this morning I have diagnosed a bit further. When turning to the right, the rubbing/binding noise comes from the left wheel area. vise versa for turning left. It does not happen in reverse either. Could it be something with the hubs?
Old 12-06-2011, 09:29 AM
vasinvictor's Avatar
Wheel bearings will make a noise somewhat like a grinding noise when turning, but it sounds to me like you have oversized tires rubbing on mudflaps or pinch weld when turning. It may not be evident while parked either.
Old 12-06-2011, 09:37 AM
vision19's Avatar
What would cause it to stop making the rubbing noise when warm though? I am fairly certain it is not a wheel bearing, as I have had those go out before.
Old 12-06-2011, 09:41 AM
You're right, tires rubbing wouldn't go away when warm. What size tires do you have, just curious. Could you wheel cylinders be sticking a bit and dragging when cold? That shouldn't only occur when turning however.
Old 12-06-2011, 09:46 AM
vision19's Avatar
I am just running the stock tire size. No lift or suspension modification either. All stock as far as I know.
Old 12-06-2011, 09:49 AM
Aftermarket wheels? Sorry to keep pressing the tire subject, but can you nab the tires size when you get uno momento?
Old 12-06-2011, 10:09 AM
sechott's Avatar
I would be suspicious about the power steering pump. The noise you hear could be a PS hose vibrating then goes away after it is warmed up.
Old 12-06-2011, 10:15 AM
^ Good idea. Also my runner's battery wasn't anchored down and physically rubbed on the PS pulley.
Old 12-06-2011, 11:49 AM
vision19's Avatar
Wheels are original and the tire size is 235/75R15. Is there any way to test and see if the PS pump is the culprit?
Old 12-07-2011, 07:18 AM
Short of listening to it while somebody turn the wheel, I'm out of idea, but I'll give you a bump to the top! Perhaps a video or sound clip would help.
Old 12-07-2011, 07:25 AM
vision19's Avatar
Thats a good idea.. Ill take a video on my phone tomorrow morning. Thanks
Old 12-10-2011, 10:53 AM
vision19's Avatar
Alright, so I got a video of the noise. You'll want to turn your volume up a bit to hear it clearly. This was a left turn, and the noise was coming from the right wheel well area.
Old 12-10-2011, 06:49 PM
vision19's Avatar
bump for video
Old 12-10-2011, 07:25 PM
Now [I]that is an odd noise. Kinda sounds like your blower motor. I dunno, somebody will have the answer.
Old 12-12-2011, 12:36 PM
vision19's Avatar
bump..
Old 12-12-2011, 12:46 PM
Bassinfool's Avatar
Did you check for a cow dying underneath the hood??
Wow that is an ODD noise! If it only happens during turning I would guess the PS pump also. I am, however, no expert on this. Just my $0.02.
Old 12-12-2011, 03:37 PM
75k5toy's Avatar
Just disconect the p/s belt. If it doesn't do the job, at least you killed one of the posibilies.
Old 12-16-2011, 05:35 AM
vision19's Avatar
to the top
Old 12-16-2011, 06:18 AM
Last night I was thinking about it- wondering if it was your power antenna or blower motor? But that's wouldn't explain why it goes away at full lock, etc etc. Still kind of sounds like a tire rubbing on a mudflap or a piece of fender liner. You may have to get somebody to drive, while you hang out of the window/door to try to narrow it down.
Quick Reply: Rubbing noise up front when turning cold
