Rough idle after AFM repair
Old 04-30-2013, 03:18 PM
asumtneer's Avatar
So I just spent the last couple hours troubleshooting my no start problem. Finally figure out how to put my AFM back together and it started back up. Problem is now a rough idle. Any chance this could still be AFM related? I had no issues with rough idle before I messed up the AFM. Any help would be appreciated. Thanks
92 Yota 4x4 truck
5 speed 22re with 140k miles
Old 04-30-2013, 03:30 PM
Philbert's Avatar
Are you throwing a check engine light? If so, diagnose it and share what you get?
What have you done to the truck recently (since it last ran)? Senders for temp coolant (and their wiring) can get mucked up, causing bad idle (I'm going through this now after my head job - messed up a thermo sensor so the ECU doesn't know when my engine it warmed up and it stays in cold start mode.
Old 04-30-2013, 03:33 PM
asumtneer's Avatar
No CEL. I was stupid and pulled the 2 screws out of the AFM and disconnected/broke some stuff on the inside. I soldered the connections back, but am afraid that it still may be the AFM that is causing the issue.
Old 04-30-2013, 03:45 PM
Philbert's Avatar
try testing the AFM:
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
You're not providing a lot of other variables to help diagnose over the internet
Good luck
Old 04-30-2013, 07:11 PM
ksti's Avatar
Kinda sounds like you toasted it.
There is a thread from someone who repaired theirs IIRC
But in most cases if you have (some stuff) broke, it probably will never work properly again.
Like suggested from "Philbert" test it to be sure.
Old 04-30-2013, 07:34 PM
ksti's Avatar
dual post
Old 05-01-2013, 02:24 PM
asumtneer's Avatar
UPDATE: so I switched out the AFM and it solved the problem. Luckily my Dad had a 92 that is out of service and I was able to nab another part off of it. Thanks for the help fellas.
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
montanatruck
02-26-2017 07:07 AM
Sidherish
08-02-2015 01:42 PM
tomczaksdiesel
07-26-2015 10:35 PM
Quick Reply: Rough idle after AFM repair
