rocker shaft assembly (22re)
Old 09-10-2010, 08:01 PM
leaver_red_jr's Avatar
Does anyone know if there are locating dowels or anything else that would prevent one from removing the front rocker shaft tower (22RE) by simply sliding it forward (with the two head bolts removed)? I want to remove the intake rocker shaft to install shims behind the #4 intake rocker, and if possible, I'd like to avoid removing the head.
The engine was making a loud tapping sound that turned out to be associated with the #4 intake valve. I currently have a shaved down nylon hose clamp (rated to 275 F) acting as a shim between the rocker arm and the rear shaft tower, and the noise is completely gone. While the nylon shim is working fine, I'd like to replace it with some washer shims.
Old 09-10-2010, 08:06 PM
yotamonsta-'s Avatar
im pretty sure That you will have to pull the head bolts out and take the complete rocker arm assembly off!! I not real sure though
Old 09-10-2010, 08:41 PM
That's what I don't want to hear! I suppose I should just do it the right way anyway, and pull the head.
Old 09-10-2010, 09:27 PM
iamsuperbleeder's Avatar
yes, there are little sleeves between the head and the rails, so no you can't just loosen them and slide them...
but...
you have to remove the head bolts to even budge the rocker rails
once you loosen the head bolts, you will need to replace the head gasket
just get a head gasket kit and do the entire process, otherwise you'll just be left with other problems
Old 09-10-2010, 10:03 PM
Thanks for the picture/information. That settles it.
Old 04-08-2014, 02:50 PM
RustyDusty89's Avatar
How do you replace those sleeves. I have one thats smashed and a old head with good sleeves in it. 22re
bigjstang
08-25-2021 12:41 AM
A2theK
01-10-2016 10:18 AM
88sasturbotoy
08-11-2015 01:56 AM
JAMGarcia
7
07-31-2015 11:46 PM
andrewtexas123
07-14-2015 04:29 AM
Quick Reply: rocker shaft assembly (22re)
