rims that dont rub???
Old 06-12-2012, 02:50 AM
spin05's Avatar
I have a 1992 toyota 4x4 x-cab that i wanted to put just plain black cheap rims on. My tire guy told me he only carried one rim that didn't hit the calipers for it. He also said most guys just grind it off ,but that they would not do that. So my question is wich brand rims are you guys putting on similiar trucks that wont rub. Thanks in advance
Old 06-12-2012, 04:57 AM
waskillywabbit's Avatar
Tons of info on this subject. Try a search and do some reading.
:wabbit2:
Old 06-12-2012, 06:19 AM
abecedarian's Avatar
Just about any rim, 15" diameter or larger with 4.25-3.75 backspacing should fit with no rubbing on the caliper.
I wouldn't suggest any less than 3.75" backspacing unless you're prepared to do constant servicing on your wheel bearings.
Old 06-12-2012, 07:22 AM
vasinvictor's Avatar
^ he made it easy on ya.
Old 06-12-2012, 08:30 AM
WHEELER8688's Avatar
if you want cheap rims, why not just use the stock steelies?
Old 06-12-2012, 08:40 AM
highonpottery's Avatar
^and paint them black.
what size tire? that will make a difference in the offset and width needed if you're going with a wide tire, like a 12.5"
Old 06-12-2012, 02:49 PM
spin05's Avatar
Wabbitt) I did try searching .Found nothing on caliper rubbing or why. Thanks for your input
highonpottery ) yea i thought about just painting my stock ones black,but one of the rear ones have to be replaced cause its bent.So i thought I might as well buy new. Oh and the tires are 30x10-15 Thankyou for your help
So i dont know. Looks like i will just wait till i find a cheap stock one and paint up all 4 black
Old 06-12-2012, 05:00 PM
LuckyStrike's Avatar
why not put some spacers behind them?
1uzRunner
63
11-10-2018 03:58 PM
Cycles
09-29-2015 06:37 AM
myotherrideisayoshi
09-29-2015 05:41 AM
Bill McBride
09-20-2015 02:51 PM
langry345
09-14-2015 03:36 PM
Quick Reply: rims that dont rub???
