Is this the rev limiter???
Old 06-08-2008, 05:24 AM
dirtoyboy's Avatar
Originally Posted by abecedarian
I'm not trying to contradict what you've already ascertained, but...
if the differential is 'warm' and suddenly the housing is 'cooled', wouldn't it be reasonable to assume that the cooled housing (caused by immersion in water) would cool the air within the housing and thus cause the breather to draw in air... and if the housing and breather were underwater, water would be drawn in?
corrrect...If he dont have a breather hose on there its probably full of water...
Old 06-08-2008, 05:53 AM
Brenjen's Avatar
Well as far as the 4x4's being different I can attest that mine has little capped stubs for vents....the truck in the signature line. The one in the back was completely covered in road grime but freed up when I hit it with the wire brush; guess I need to extend my diff breathers.
Old 06-08-2008, 08:57 AM
just a 22re's Avatar
How???????????
Originally Posted by iamsuperbleeder
I wasn't aware my 22re had a rev limiter...
ok if this is even a 22re in in this picture how the hevens dod you get it to rev this high and does it even make any power at the 9k mark anymore i know mine stops making power at around 37k but thats when you are going 83 mph and shift it into 1st he he
no i never did that but still how did you get it to rev to the 9k mark man holy craptacular
a 22re at 9 does this when it revin up he he
Old 06-08-2008, 09:06 AM
91Toyota's Avatar
...and oil of course
I just put gear oil in the rear a couple months ago
Old 06-08-2008, 09:31 AM
  #25
dirtoyboy's Avatar
Oh right! That makes complete sense...You should be fine... gears are cheap anyways
Old 06-08-2008, 09:32 AM
  #26
dirtoyboy's Avatar
Originally Posted by bob200587
and if the diff and the water had temperatures that were close to the same, then it wouldn't suck water into the diff.....
Do you enter water that is 200 plus degrees?
Old 06-08-2008, 09:49 AM
  #27
91Toyota's Avatar
lol...I'm changing it soon anyways. I don't drive it since I just took the intake side off
I prefer to boil my water first
Old 06-08-2008, 03:02 PM
  #28
iamsuperbleeder's Avatar
Originally Posted by just a 22re
ok if this is even a 22re in in this picture how the hevens dod you get it to rev this high and does it even make any power at the 9k mark anymore i know mine stops making power at around 37k but thats when you are going 83 miles per hour and shift it into 1st he he
lmao, I was waiting for someone to comment on that.
Rotory engine swap!
haha, JK
the tach lets you adjust the shift light point without the truck running; just turn the dial and the needle moves to the RPM you want the shift light come on; I keep it set at about 4.5k.
my limiter is about 6,250rpm on my 91 22re manual 4x4
Old 06-08-2008, 04:35 PM
  #29
yeah thats what i though i have the same tach but the silver one and i have to push a button for it to go into the shift set lol cause i was going to say man my god lol an dyes mine is set at i think 4800 not sure its raining out and i just put half doors on her so i have to wait fo rit to stop raining so i can drive her and see what shes set at! lol
Davebarbier
11-03-2015 03:28 PM
Jdgarrison
10-01-2015 05:22 PM
Jdgarrison
10-01-2015 02:11 PM
shredder4286
10-01-2015 01:09 PM
voiddweller
09-28-2015 11:21 PM
Quick Reply: Is this the rev limiter???
