Replacing green coolant with Toyota red.
#41
To add to what others have said about Toyota's 100k mile change interval:
It only applies to the pink (sllc- super long life coolant)
And after the first 100k they recommend every 30k. It's just a ploy to keep the calculated cost of ownership low and to a lesser extend, have less impact on the environment. Its all about cost of ownership these days. Lower cost of ownership = more car sales.
Think 100k mile iridium plugs, lifetime auto trans fluid, timing chain, and now 10,000 mile oil change intervals.
The red (llc- long life coolant) I believe was recommended every 30k. But don't quote me on that one. I've always changed my green coolant every 2-3 years.
The Toyota Red is just like the green, same service intervals.
#44
Never heard of water less coolant. Actually, water by itself cools much more efficiently than any coolant. The reason coolant is used is for corrosion protection, lubrication, and freeze protection.
#45
Evans Waterless Coolant is one.....I know nothing about using it.
A topic for a new thread......possibly.
#46
#48
Any fluid/vapor pressure that the cooling system can exert on a headgasket is trivial. Those pressures cannot contribute in any meaningful way to headgasket failure.
Max cooling system pressures are well under 20psi.
Combustion pressures are hundreds of psi, alternating with vacuum
hundreds of times, if not thousands of times per minute.
That, coupled with radical temperature gradients, and the dissimilar coefficients of expansion of iron and light alloy, do the job on headgaskets.
#49
Umm... the radiator cap realeases pressure. That's what it's for. Waterless coolant is bad news.
Why would you want HIGHER internal temperatures? Higher temps reduces engine efficiency. Our fans are mechanical so the whole "save HP by not running fan" is a bunch of baloney.
#50
I saw that "not running fan" comment on the website and chuckled.
#52
#55
There is an excellent thread that details exactly what is going on with the various types of coolants. Well worth the read: https://www.yotatech.com/forums/f116...nt-faq-192781/
#56
1 Post
Your joking right? The ratio effects the freezing point as well as the boiling point. Running straight water will boil at 210f- 100c. If that happens you'll probally start blowing hoses from a huge pressure increase. The coolant also acts as a lubricant for the water pump. If you run straight water your water pump bearings won't like it. Ever think about corrosion? Corrosion inhibitors are in your coolant as well. Have fun cleaning your rusty block.
#57
Hate to argue, but that won't happen. The cooling system in the truck is pressurized, so water will not boil at 212F like it normally would.
A lot of drag cars run straight water in their cooling system without a problem.
#60
good thread.
since i'm sold on di/distilled water only in radiator systems, and I run the cheap peak antifreeze, I went to their website to see how much of a difference tap water makes:
"Can I mix ordinary tap water with antifreeze?
Yes, tap water is commonly used for mixing with antifreeze, however, deionized water or distilled water is preferred. Do not use water softened with salts to mix with antifreeze"
http://www.peakhd.com/product-lines/peak/faq/
