Replacing 1989 22re Headgasket
Old 11-13-2011, 12:51 PM
  #61
thedrewski86's Avatar
Good luck to you. I really hope you don't have to do your timing chain next week! The more I get into mine the more I expect my head gasket to be fine, I really feel like my timing chain was the only problem.
It's stupid not to do the head gasket though, gotta be done!
Old 11-18-2011, 05:33 PM
  #62
22r2tuff's Avatar
Originally Posted by irab88
i never touched that plate, but did take the pipes off. no issues, as long as you don't over-torque anything. though that's some good advice, and it makes sense. i just found it easier to rest the head without them on
carry on haha
So, I'm about to tackle this thing all out tomorrow morning. Where I let off, I spent hours trying to get the damn lower-left bolt out of this 'plate'. I removed the pipes while the head was off, but put the 2 bolts back in to keep the gasket sealed. Its looking like I should have put these pipes on before I lowered the head back down onto the block. Should I be able to access this nut? I tried every tool and tool combination I've got, I'm going to try more with the wrench tomorrow morning, and get someone to look from underneath to see if I can get the wrench onto the nut. And yes, mines a like, stud and nut for some reason. So I need a deep socket or open-ended tool. Deep sockets won't fit between the firewall and the head, and I can't get any wrenches to grab it. I hope I don't have to pull this head again, lol...
Old 11-19-2011, 04:59 AM
  #63
Aw that sucks! I've heard it can be done, I wouldn't pull the head though. From reading other posts, this is a big fear of mine. I've been telling myself over and over again to hook those lines up before I put my head on!
Others have done it though and they got them bolted on, it's just more difficult.
Old 11-19-2011, 06:02 AM
  #64
22r2tuff's Avatar
ok, well I'll just keep trying then, lol.
Old 11-19-2011, 06:08 AM
  #65
irab88's Avatar
yeah, i was able to use the box end of a wrench. actually, it was easier to stand where the radiator was, but i understand if you didn't take out as much stuff as i did
Old 11-19-2011, 08:04 AM
  #66
22r2tuff's Avatar
I've been under the truck, in front, beside, sitting in the engine bay, no luck. very frustrated right now.. going to have to pull the head it looks like.. I know I "should" wait until monday and buy a new head gasket, but is it absolutely necessary? I've only torqued down the head..
Old 11-19-2011, 08:15 AM
  #67
JPL
JPL's Avatar
I wouldn't re-use a head gasket that has been torqued down (even if it's new). In a pinch you can try moving the engine from the firewall.. Maybe loosen the motor mounts. I'm new to Toyota engines but have done plenty swaps. It might be as easy as removing the tranny mount/bracket and/or removing the motor mounts. This still sounds like less work than removing the head again and replacing the pre-torqued head gasket. Good luck and let us know. I'm sure one of the real 22r pros with chime in soon..
Old 11-19-2011, 11:53 AM
  #68
22r2tuff's Avatar
Thanks for the advice, yeah I thought of moving the engine somehow, I'm also not familiar with toyota, not with anything very much yet, couldn't even see the motor mounts.. so went and bought $120 worth of wrenches, flex-heads, ratheting, stubbies, and curved ones lol.. all 60% percent off i got the nut off! finally, with the help of a mirror, and a helper holding it, finally got it with a S bend wrench.
I removed the fuel filter (pretty sure thats what it was) so I can slide one of the pipes into place alongside the head. Then noticed a top nut on my starter (pretty sure its the starter) was almost all the way backed off.. lol? Maybe a friend did it and I didn't notice. anyhow, tightened that back down, just about to bolt the pipes onto the back, and put the fuel system/intake manifold all back together.
Old 11-19-2011, 01:14 PM
  #69
Man I'm glad you got it! Didn't want to hear nothing about you taking off that head again, let alone re-using a head gasket (big no-no! )
Old 11-19-2011, 02:21 PM
  #70
22r2tuff's Avatar
haha i'm very glad too, lol. love these smilies.. but yeah, I bolted the (egr?) back on, thing right beside the lower intake manifold, with 3 bolts, along with the intake manifold resting in place, a pipe bolted on, just trying to remember if the wiring harness was under the fuel rail or over it.
Old 11-19-2011, 02:24 PM
  #71
This help maybe? (Mr. T because he rocks)
Old 11-19-2011, 03:26 PM
  #72
22r2tuff's Avatar
yes that is very helpful!
Old 11-19-2011, 10:45 PM
  #73
22r2tuff's Avatar
got a fair amount done today, got almost all intake and exhaust manifold bolts in. exhaust side is pretty much done, except for distributor. I'm missing bolts, frustrated. I'll blame my tool-happy friends who helped the other weekend, lol.. will just be glad when this thing is on the road. Looking forward to putting more work into it, just need a break for a while, lol.
Old 11-20-2011, 08:20 AM
  #74
JPL
JPL's Avatar
Sucks losing hardware after a big project like that. Just make sure none of them found their way into the head, timing cover, intake, or exhaust. That is a big project but glad you're almost done. Take your time and make sure you didn't miss anything. Whenever I do a rebuild or tear the engine down I'll turn the engine over by hand a few times before starting her up (once everything is installed).
Old 11-20-2011, 08:28 AM
  #75
22r2tuff's Avatar
Thanks for reminding me to do that, haha. I'm going back outside soon, thanks for everything.
Old 11-20-2011, 10:13 AM
  #76
Staff
Terrys87's Avatar
Just got done reading yor thread. I was going to mention the fuel filter causing a hold up. It is tempting to put it on with everything out of the way, but seems like I always had to take it back out for some reason or another. Now I just make it my last thing to do.
I have replaced quite a few timing chains and learned something on your build. I didnt know there was a dimple/slot/notch on the distributor.Thanks irab88
I was just talking to another Yoattecher, and we have both done this. Make sure when all is said and done, that you have your distributor bolt tightened down. It if gets to far advanced on timing, you can get the cherry manifold.
Dont know if I missed it, but watch the bolts on your timing chain cover. There are different sizes and you can get into a problem if you get them out of place.
Looking good and great job. I think you will like the 22re.
Old 11-20-2011, 12:15 PM
  #77
22r2tuff's Avatar
Thanks!!
Yeah, live and learn. Next time, many things will be much eaiser now.
I'm about to line that distributor gear up now. You simply mean, make sure its tightened down all the way, correct? I'm assuming a cherry manifold implies it being very hot.
I did hear somewhere that the timing cover bolts were not all the same. Luckily didn't have to get into that this time. thanks for the heads up I think I'll like it too
Old 11-20-2011, 12:22 PM
  #78
irab88's Avatar
don't forget!
https://www.yotatech.com/forums/f116.../#post51817138
Old 11-20-2011, 04:09 PM
  #79
22r2tuff's Avatar
I got it in correctly, I believe. Only thing I'm struggling with now, is figuring out where certain things go on the intake manifold side. I think I'm gonna put on the upper chamber, and just see if that helps. I'll post some update pics for reference.
just a quick pic of the truck and my car (cars dirty)
wrenches i bought.. S bend helped get it off
Putting distributor on
I can't figure out where this goes. any ideas?
Old 11-20-2011, 04:52 PM
  #80
gottadog's Avatar
that last picture is a ground strap that gets bolted on right between your pointer finger and middle finger. Place the upper intake on and then that and then the bolt.
Quick Reply: Replacing 1989 22re Headgasket
