Removal of Pin in leaf spring?
Old 09-15-2011, 08:35 PM
96vettelt4's Avatar
95 yota P.U. 4x4..adding a leaf for a 2 inch lift from Toytec. Have everything removed and down to the pin which is in the center of the leaf spring. This pin has to be removed in order to add the extra leaf spring. No bolt head, no thread, no nothing..PB it but it wont budge..how does this pin come out..Toytec says to remove the Pin and discard it as they give you a new bolt to use in its place..but how to remove it is the question....thanx....G
Old 09-15-2011, 09:10 PM
myyota's Avatar
You will probably have to grind the head off of the pin and drive it out with a hammer and punch. Then put it back together with the new hardware in the kit.
Old 09-15-2011, 09:30 PM
cman1's Avatar
yep, the nut is on the bottom,at least mine was,a week ob pb blaster got it off.i just took mine out,it rode like a lumber wagon.i had a busted shock and didnt even know it.
Old 09-16-2011, 03:44 AM
angrybob's Avatar
^^^^X2^^^^
The nut should be on the bottom of the leaf pack. Mine was when I added a mini-pack.
nvdesertrunner
05-11-2020 08:18 PM
4x4-runner
04-18-2017 09:08 PM
Griff
93-98 T100s (Build-Up Section)
09-23-2015 10:11 PM
88sasturbotoy
08-11-2015 01:56 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Removal of Pin in leaf spring?
