Rear oil seal on transfer case
Old 04-06-2012, 09:50 AM
  #41
rockroller's Avatar
oh just wondering how much was the new parts ?
i havent changed the gear oil yet but will do it soon as i fix the leck
my trans a 5 speed r150f so whats the right gear oil for the trans and the transfer case? 90 wight?
Old 04-06-2012, 05:20 PM
  #42
Grego92's Avatar
I updated the thread with approximate pricing and oil specs from the manual.
You can download your own copy of a manual from here for your make/model truck to answer many questions.
http://www.ncttora.com/fsm/index.html
You can also go to the toyotapartseast.com website to find parts diagrams for your make/model truck.
Old 04-06-2012, 06:06 PM
  #43
rockroller's Avatar
ok thanks grego just one question that been on my mind how long to the 3vze v6 last ? i mean wear down till the rings and ˟˟˟˟ start to get bad
asking becuase mine has 404 347 km on it and hasnt been touched yet
so i need it to last till the 3.4 build is ready to drop in
damn man i need pic to put up
Old 04-06-2012, 08:51 PM
  #44
Grego92's Avatar
Don't know, got a 22RE and that question is for a different thread, good luck.
Old 04-07-2012, 01:21 PM
  #45
toastyjosh's Avatar
Dude you guys rock!!!! Thanks rasta rocket and grego for the step by step!!!
Old 07-21-2012, 10:24 AM
  #46
woodyth's Avatar
PROBLEM: I don't have a torque wrench or access to one. can I just tighten the 30mm nut snugly?
One of the perks of living in the middle of no where!
Old 09-16-2012, 09:52 PM
  #47
FreedomStalker83's Avatar
Amazing write up! thanks!
Old 09-16-2012, 09:59 PM
  #48
4Crawler's Avatar
Originally Posted by Grego92
If you need to replace the fluid that was lost during the leak, the below is from the online pickup manual (Page MT-24). I lined out the "GL 5" since most agree that GL 4 is the way to go. Some popular synthetic brands that are used are Amsoil, Redline, and Royal Purple.
If I did something wrong please correct me and I'll put it in the thread so nobody else screws up!
Good writeup.
For the transmission, GL-4 is the way to go for sure. In the t-case, you can pretty much run anything you want as it is not synchro-mesh. GL-4 or GL-5 oil will work just as well. Some folks go with GL-4 in case you get an oil leak between the trans. and t-case. But you can run the same GL-5 oil you run in the axles, so use whatever you have on hand. I do find synthetic oil in the t-case lets it run cooler and with dual cases, you can feel the reduction in heat coming into the cab with synthetic oil.
Old 11-16-2012, 02:28 PM
  #49
92shawman's Avatar
This thread is gold for this issue! I had started my own thread because I wasn't finding any info, but after searching for a while longer and finding this thread, just about all of my questions have been answered. Sweeeet
One question, do any of you know if those part numbers work for a 3vze R 150F transmission?
Old 04-21-2014, 08:42 PM
  #50
morena67's Avatar
Changed mine a few days ago... Great thread... Thanks...!
Old 03-01-2016, 06:47 AM
  #51
joeynational's Avatar
bringing back an old thread, but did anyone put FIPG on the outside of the seal. The portion that seats in the housing of the transfer case? Or is that only neccessary when you have a metal type seal, not the rubber type?
Old 03-01-2016, 07:00 AM
  #52
MudHippy's Avatar
Who said it was ever necessary?
Anyway, no I never have. And probably never will. Since I've installed many of both types without, and never had one leak for lack of, RTV. So why mess with success?
Old 03-01-2016, 09:43 AM
  #53
I used to work on heavy equipment and everytime we put a new metal lip seal in something we put FIPG around the outside first. Just checking based off my previous experience. Must be a Caterpillar thing only.
Old 05-22-2018, 06:54 AM
  #54
RAD4Runner's Avatar
RAD4Runner's 1986 4Runner's Transfer Case Output Seal
Thanks to Grego for the illustrated procedure above.
Do you guys think Permatex Ultra-grey would be a good substitute for Toyota sealant here?
Originally Posted by joeynational
... did anyone put FIPG on the outside of the seal. The portion that seats in the housing of the transfer case? Or is that only necessary when you have a metal type seal, not the rubber type?
Originally Posted by MudHippy
...Anyway, no I never have. ...
I agree with no sealant on rubber to metal interface.
The Seal P/N 9031138140 is available from Toyota Parts Deal:
Old 06-09-2018, 09:04 AM
  #55
RAD4Runner's Avatar
RAD4Runner's Transfer Case Notes
Figured I'd just add to this thread.
Found a youtube video of replacing rear oil seal on transfer case
keywords: transfercase, oilseal
Old 04-23-2020, 02:52 PM
  #56
Phillip5280's Avatar
transfer case output flange nut help
Hay everyone,
I have a 1987 4runner MT that I was attempting to change the rear output seal on. When I got the drive shaft off, the nut wasn't steaked it looked like either someone reused the nut and didn't steak it or the nut backed off(may be loctite?). Then i tried to take the nut off.. Nothing...
I tred to get a chisel under the part that was steaked but I think it just made it worse.
I then tried to get the nut off but nothing worked. I used an impact wrench(small cordless) and tried a 24" breaker bar with some heat(small butane torch) and used the floor jack with the braker bar. The nut took some abuse from the impact and my hitting it with the chisel.
What should I do?? The braker bar made the transfer case turn just a bit when I was in 4L. I think I'm going to go get a chain and hook it up to the flange and see i can get it off that way.
should I use more heat??
Bigger impact??
Old 04-23-2020, 03:51 PM
  #57
millball's Avatar
A decent air operated impact should remove it even when staked. When the nut turns it'll just push the staking back out..
You can drill a couple holes in a piece of strap, or angle iron, and bolt that to the flange and use a cheater pipe to belay the flange solid.
The torque on that flange nut should only be 90-95 foot pounds.
The following users liked this post:
Phillip5280 (04-26-2020)
Old 04-23-2020, 04:15 PM
  #58
Grego92's Avatar
When I did mine, all I had was a harbor freight plug-in impact wrench and it came right off.
The following 2 users liked this post by Grego92:
Phillip5280 (04-26-2020), RAD4Runner (04-25-2020)
bigjstang
08-25-2021 12:41 AM
andrewtexas123
07-14-2015 04:29 AM
Kalihi,HI
07-09-2015 04:29 PM
toyoda8488
07-05-2015 10:18 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Rear oil seal on transfer case
