Rear driveshaft came apart, how to align when putting back together?
Old 06-05-2017, 09:23 AM
artemyk's Avatar
I was removing my rear drive shaft when it came apart into two pieces. Now I'm not sure how to align the 'teeth' when putting them back together. Is there a guide somewhere to do this? Thanks greatly.
Old 06-05-2017, 09:44 AM
millball's Avatar
See this:::https://images.search.yahoo.com/yhs/...g&action=click
Old 06-05-2017, 12:45 PM
scope103's Avatar
The FSM gives advice based on the direction the grease fittings point. (Which seems to include the "phasing" of which millball speaks.)
http://web.archive.org/web/201204171.../3propelle.pdf
Old 06-05-2017, 03:10 PM
artemyk's Avatar
Thanks, that's very helpful. So I just eyeball the alignment? If I'm off by a tooth or two, will I have drive shaft vibration / problems?
Old 06-05-2017, 03:47 PM
Fossilized
Staff
dropzone's Avatar
yep, some
Old 06-06-2017, 09:23 AM
RJR
RJR's Avatar
There aren't that many splines around the circumference. You should be able to just lay it out on a flat surface and get it exactly right with a little care. No real excuse to be off a tooth or two. Just take your time.
Old 06-06-2017, 03:47 PM
artemyk's Avatar
That's encouraging -- I will eyeball my best. Thanks!
