Radiator replacement
Old 12-24-2009, 06:37 AM
1990yota-pickup's Avatar
plastic radiators will get stress cracks and tend to leak around a seam..
make sure you hae a good ground on your cly. head.. and a good ground on the radiator
Old 12-24-2009, 10:59 AM
mt_goat's Avatar
I agree with grounding the head, block, fan motor, etc...but not sure about grounding the radiator. I think grounding the rad could actually promote electrolyis through the coolant, not a good thing.
Old 12-24-2009, 11:07 AM
i know if you do not ground the head on 22r/re it does promote electrolyis. and the aluminum head will ionize.
Old 02-03-2010, 02:45 PM
joeynational's Avatar
has anyone picked up a radiator off ebay seen some pretty cheap 33-60$$? but i'm not sure if they are worth it
Old 02-03-2010, 03:02 PM
  #25
b4wheeler's Avatar
I had my factory radiator cleaned, flowed and the small leak in the upper tank braised for $80.....
Old 02-03-2010, 05:43 PM
  #26
DanStew's Avatar
I did the Summit racing radiator. $117. I was happy and it is working fine. Only issue i had was the first one they sent it had a gauge in the fins. I called, they sent me a new one, and i sent the old one back. real easy. Its been 2 years now. Oh with this radiator i found i had to trim the shroud to fit, it was off a touch.
Old 02-03-2010, 06:06 PM
  #27
Wrenchinjoe's Avatar
Funny how things run in cycles. My radiator has developed several pin-hole leaks on the top as well, figured I'd replace it before it opened up and left me hot and dry on the side of the road.
AutoZone, Advance Auto, O'Reilly's and Summit Racing want $150 to $170 for radiators. I also saw the ones on ebay for $38.46 plus $30 shipping.... that is either a great deal or a rip off
Advance Auto has a $20 off promotion plus free shipping online, making their Ready Rad about $132, FYI.
Old 02-03-2010, 06:26 PM
  #28
myyota's Avatar
You can get a good quality 3 core replacement from radiator barn for about 150.00, i have one in my 4Runner and havn`t had any problems.
Old 02-03-2010, 06:57 PM
  #29
Tragic Drive's Avatar
Originally Posted by flyingbrass
I bought a 3 row CSF from Radiatorbarn a couple years ago. It works, as in it fit, cools well and doesn't leak.
The drain plug is a pain if you're used to the nice downspout on OEM radiators. Instead of having a tube to direct the coolant down into a bucket as you back the plug out, it just sprays out everywhere as you loosen it, then shoots out rearward.
This.. One other issue I've noticed was how the fan shroud bolted up.
The factory radiator has the nuts tack welded and the aftermarket CSF uses tinner nuts.
Other than that the CSF works fine.
Old 04-05-2010, 05:27 AM
  #30
angrybob's Avatar
Originally Posted by InternetRoadkill
I think mine came from "radiator barn" (???). Maybe. It was a couple of years ago. I bought a V6 radiator for the 22RE and it's working wonderfully and wasn't all that expensive.
I have a V6 radiator in my new (to me) '87 4Runner w/ 22RE. I was going thru it this weekend and replaced the belts and fan clutch and noticed there was no fan shrowd. Looking at the V6 shrowd pics on ebay it appears that the fan hole in the shrowd is off- center and seems that the L4 fan ass'y is centered.
QUESTION - Will the V6 shrowd fit with a 22RE?
Any help would be appreciated.
Road Bull
10-10-2015 04:55 PM
Rkellerman
07-12-2015 08:42 AM
Poncho0206
07-10-2015 06:21 PM
horunner1x
07-10-2015 06:33 AM
Avenged
07-09-2015 07:55 AM
Quick Reply: Radiator replacement
