Quick question on ujoints
Old 10-10-2012, 10:11 AM
skinny's Avatar
Looking to rebuild my front drive shaft and I'm at work with limited material and time
Can some one tell me if all the u joints are the same in the front shaft if not how about links to the parts or info
Old 10-10-2012, 10:22 AM
Marc's Avatar
I can't help with the part numbers but it would help if we knew what you were working on.
Old 10-10-2012, 10:55 AM
skinny's Avatar
Oops 94 runner 3.0
Old 10-10-2012, 03:35 PM
MudHippy's Avatar
No. The u-joints in the front driveshaft are not all the same. The front u-joint(where the driveshaft bolts to the differential) is a different size than the two u-joints in the double cardan(where the driveshaft bolts to the transfer case).
Originally Posted by acicomp
The part number for the u-joints in the double cardan are:
(Same part, just cross referenced the part numbers.)
Precision #513
Neapco #1-5800
Auto Zone #1-5800DL
Rockford #407-10
Spicer #5-2532X
The standard u-joint for the front joint (Differential end of the u-joint) is pretty common and stocked at most parts stores. You may have to order the two needed for the double-cardan (CV Style), but they are available. The dealer will tell you that you have to buy a complete shaft, but you don't. The repair parts are readily available, just not from the dealer as OEM parts.
https://www.yotatech.com/forums/f115...t-size-230481/
Note: Precision is now Precision/Moog(but their part numbers haven't changed). And their u-joints are also sold under the Federated brand name(with identical part numbers). Meaning, Federated #513 is also the correct size u-joint for the double cardan.
Hint: DO NOT buy u-joints from AutoZone. They don't fit correctly(in some cases), and the design is flawed. They make them with a zerk fitting that can't be accessed with the u-joint installed. Which means they're greasable(that's a good thing), but you can't grease them once they're installed(WTF? that's retarded).
Old 10-10-2012, 04:33 PM
skinny's Avatar
Thanks a ton
Old 10-10-2012, 05:13 PM
MudHippy's Avatar
You're welcome.
Here's the OEM u-joint w/part # for the front of the driveshaft(single cardan joint), if you're interested. FYI, it also fits the rear driveshaft(all positions, exc. double cardan joint if applicable).
IMO, you can't beat the stock u-joints on these rigs. Anything stronger, is too strong(u-joints are cheap to replace when they fail, driveshaft yokes aren't). And none of the aftermarket u-joints I've seen have seals that are as well designed as OEM.
Old 10-10-2012, 06:54 PM
kuzbro's Avatar
Just call me "OEM Slim" My 90 Truck still has the original joints. I been thinking about replacing them. Thanks.
Old 10-11-2012, 04:53 AM
Pat8942's Avatar
IMO Precision joints are junk, Spicer is a better choice, just my opinion.
jasonty
41
12-23-2018 01:00 PM
thefishguy77
08-09-2015 04:15 PM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
icentropy
07-14-2015 10:23 AM
Quick Reply: Quick question on ujoints
