Question on Cali 22RE O2 sensor
Old 04-19-2008, 06:40 AM
xdogg's Avatar
I have a '94 22RE Pickup w/146,000 miles.
The oxygen sensor behind the cat (its the CA emissions style exhaust) is so rusted that the nuts broke off and the o2 sensor isn't being held on by anything.
Rather than replacing this after-cat sensor, can I just weld something over the hole instead to bypass this o2 sensor? Or would that screw up the ecu?
Old 04-19-2008, 11:06 AM
xdogg's Avatar
13 views and no love?
Surely somebody has tried bypassing the 2nd O2 sensor on the Cali emissions?
Old 04-19-2008, 04:06 PM
abecedarian's Avatar
You could do it, I suppose, but you'd most likely fail the visual inspection the smog shops are required to perform.
The engine should run fine but may throw an error code.
Old 04-19-2008, 04:22 PM
xdogg's Avatar
I forgot to mention that I live in Mississippi now so I don't have to worry about visual inspection.
We have no emissions checks or inspections!
Old 04-20-2008, 08:34 PM
norcalsvx's Avatar
i run 2 o2 on my 94, with out 2 you would get a check engine light you should have the weld in a new bung on the exhaust pipe and put a new o2 in there.
Old 04-20-2008, 09:17 PM
stevec8720's Avatar
or you could do what i did by a o2 simulator from http://empirepao.com/ no engine light you can completely remove the sensor and now you can gut the cat like i did. catalog number 1301 in the o2 simulator section. it was a really good quality item and had a very simple plug and play install.
Old 04-21-2008, 07:36 AM
norcalsvx's Avatar
i run header w/ no cat and both O2 sensors with no check engine light.
anndel
09-10-2015 08:50 AM
Kreedy1
09-08-2015 06:33 PM
LucasF249
09-08-2015 01:17 PM
zz_denis
09-06-2015 03:43 PM
moparbay
09-03-2015 12:48 PM
Quick Reply: Question on Cali 22RE O2 sensor
