Pulling the fuel pump help please
Old 01-09-2010, 05:53 PM
Yotapowa's Avatar
I have a running issue with my truck, most likely the fuel pump. I have a spare for it, I was wondering if it was easier to drop the fuel tank or pull off the box to get at it?
Also, is there an in tank fuel filter that i would need to replace?
86 22RE
thanks
Old 01-09-2010, 05:59 PM
1985yoda's Avatar
Take the bed loose and slide it back about 18". That's the only way to go.
Old 01-09-2010, 06:48 PM
Yotapowa's Avatar
OK thanks
Old 01-09-2010, 07:01 PM
sb5walker's Avatar
86 22RE
thanks
There's a nylon intake screen called a "sock" that does need to be replaced. Also a short length of rubber fuel line, and a few other parts. autohausaz is having a MONSTER sale on Denso pump kits that come with sock & all the little parts - just $130 which is an incredible deal. Here's what the two main sock types look like - IDK which is the right one for your 86:
EDIT: Forgot to mention; you'll want a pump bracket gasket and probably a new set of bracket screws which you can get from the dealer. Your current screws are probably completely rusted.
Old 01-09-2010, 07:18 PM
Yotapowa's Avatar
OK sounds good. I have a suspician that the pump itself is ok, but that the sock is almost completely clogged up. When i beat my truck up a bit my driving over speed bumps fast and over curbs and other bumps it often works better for a short period of time
Old 01-09-2010, 07:50 PM
sb5walker's Avatar
Could also be corrosion. But while you're in there, may as well replace the pump. If it's original it has certainly give a lot of years of good service. Probably earned its retirement, lol.
Old 01-10-2010, 06:27 PM
shaeff's Avatar
Before you bother with any of that, jump +B and FP in the diagnostic block. Use heavy gauge wire. If the truck runs, and drives well the fuel pump isn't likely to be the problem.
Jumping those terminals will feed the pump 12v, bypassing the COR.
Old 01-10-2010, 10:22 PM
milehigheric's Avatar
It only feeds the pump switched ignition power from the EFI relay....It is always a good idea to check that you actually have 12V at the diagnostic panel (with ignition on) before you come to conclusions.
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Tyler Cunningham
07-11-2015 10:18 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Pulling the fuel pump help please
