proper vafm swap for the 3vze
7M-GE & 3VZ-E
3VZ-FE
I've only heard of 2 sizes. Like I said though, I have no way of verifying that. The 7M-GE is the same size for all I know.
3vz-e AFM is not too small - proven via math!
3VZ-FE
I would think it would make the biggest impact at wide open throttle, only because of the immediate availability of air volume. So that should net you a snappier throttle response. I am just talking out of my... i have no real proof.
#25
Keyword: Volumetric Efficiency
If you haven't modified it from stock significantly. You won't gain much, if anything. Any power gains from increased air flow would likely only be in the mid-high rpm range anyways even if you did modify it.
Airflow vs HP
Engine airflow can be directly related to hp developed. The volumetric efficiency of an engine is always the highest at its torque peak. Above this rpm, pumping efficiency drops off.
I did my research FIRST too, as usual...
#26
Eureka!
which vafm to look for?
talking about the oem part numbers.
22250-62020-camry ,lexus v6
22250-74180-celica 3sgelc engine
22250-43230-cressida 2.8L
22250-43150-supra 5mg
22250-61010,22250-75020-land cruiser
22250-74100-previa non s/c
this page contains all toyota vafm oem numbers
http://www.autoairflowsensors.com/index.php
#28
whereAreMyPants
07-22-2015 03:32 AM
