Problem indentifying tranny
Old 11-20-2012, 07:08 PM
luke86pickup's Avatar
Hey guys I have a 1986 toyota 4x4 5 speed. My transmission went out a few days ago and I'm positive it's the transmission but I'm having a hard time figuring out which transmission it is and what year of the trucks I can pull a used one from.. Thanks!
Old 11-20-2012, 07:55 PM
TrikeKid's Avatar
If your truck is carbureted you have a G54, if you're EFI, you'll have a W56. One can be used in the place of the other but the G series uses a forward shift case and most W56's use a top shift. A top shift can be used behind a forward shift trans but not the other way around and will come through the floor in a slightly different location.
Basically, find a trans out of a 4 cylinder 84-88 truck with the same drive-train (Carbed or EFI) you already have for the least headache.
Old 11-20-2012, 09:49 PM
rokblok's Avatar
Go to Marlincrawler.com They have a pretty accurate transmission identification chart.
Old 11-21-2012, 09:05 AM
junkyardog05's Avatar
They Make a G,W, and R series trans for that year truck,
G - 8 bolts in the shifter plate
W - 6 bolts in the shifter plate
R - is the 22RETurbo engine
Hopes that helps you some
Old 11-21-2012, 09:27 AM
iliketoyota's Avatar
just look at the tag on the firewall and it will tell you
Old 11-22-2012, 05:06 AM
SPARKS89's Avatar
As long as it's not a turbo 22re you should have the W56B transmission. Call a dealership with your VIN and they can confirm it for you. Be careful when searching for a replacement.....there are 5 different W56s.
Old 11-23-2012, 03:06 PM
Alright and I now have another problem.. I think at one point or time the 22r motor in my truck was infact a 22re motor. So is there any other way to tell in case someone has did a complete motor an tranny swap ?
Old 12-07-2012, 08:43 PM
SPARKS89's Avatar
The best way to find out is to get the number of the engine block and transmission. Then call the dealership with your VIN and compare.
Old 11-01-2013, 04:20 PM
no one's Avatar
All those ideas are great; however, what do you do when you have a transplanted Toyota transmission? Where are the casting points or stamps on the case? I beleive that I have a R150F transmission but not sure of the year, mechanical vs. electronic speedometer cables.
Old 11-03-2013, 05:28 PM
no one's Avatar
T.o.t.
shadowbirdie
07-21-2015 10:38 PM
Iceman4193
07-15-2015 04:48 PM
jakebarrett
07-10-2015 07:15 PM
madxman21
07-09-2015 10:26 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Problem indentifying tranny
