Preference for O2 Sensor Brand?
Old 06-08-2006, 04:07 AM
TNRabbit's Avatar
Question Preference for O2 Sensor Brand?
Does anyone have suggestions for the best brand of o2 sensor? NGK or Denso? What are your experiences with each?
Old 06-08-2006, 05:12 AM
rentedmule's Avatar
NGK worked well for me. It's the only brand I've used on the yota so I can't really give an opinion on others.
Old 06-08-2006, 05:27 AM
regularguy412's Avatar
Either NGK or Denso is fine. Try to avoid Bosch or any of the generics.
Mike in Ar
Old 06-08-2006, 05:40 AM
91_4x4runner's Avatar
I have a Bosch and it has worked for the past err... 80 miles? I haven't been driving my 4R for the past few days. I would've gone with an OEM one, but I didn't have input on the buy, my dad did. Why does everyone seem to avoid Bosch like a plague?
Old 06-08-2006, 06:16 AM
kyle_22r's Avatar
i personally think bosch stuff is low quality compared to denso or NGK. their plugs always seem to fould up, can't vouch for their O2 sensors.
Old 06-08-2006, 07:45 AM
97Limited's Avatar
NGK works good for me too!
Old 06-08-2006, 12:39 PM
LS1Steve's Avatar
wheres a good place online to get both sensors cheap??
Old 06-08-2006, 01:18 PM
Elton's Avatar
for your 4runner
denso $68 http://www.sparkplugs.com/more_info....72327&pid=1968
ngk $38 http://www.sparkplugs.com/more_info....72327&pid=3992
Old 06-08-2006, 05:34 PM
LS1Steve's Avatar
awesome, thanks!
so are the front and back ones the same?? i just buy two of these?? its been 215k miles, i figure its about time to replace, my mileage is about 11
Old 06-08-2006, 07:15 PM
TNRabbit's Avatar
Originally Posted by LS1Steve
awesome, thanks!
You need to look underneath and see if yours is in front or behind the catalytic converter. You only need one.
Old 06-08-2006, 10:15 PM
midiwall's Avatar
Originally Posted by TNRabbit
You only need one.
...and if there're two, then that's the front one.
Old 06-08-2006, 11:29 PM
humanoid's Avatar
How easy is it to change these things on a Taco? Bolt off bolt on?
Old 06-09-2006, 05:14 AM
midiwall's Avatar
Yeup. Should take about 10 minutes including the time to get out your tools.
Old 06-09-2006, 03:10 PM
Elton's Avatar
thats if you can break the bolts lose
Old 06-09-2006, 09:10 PM
humanoid's Avatar
Some good penetrant the night before on the bolts should do the job, no?
Old 06-09-2006, 09:19 PM
midiwall's Avatar
PM Blaster will help, but a lot depends on the age and the "home" of the truck. Mine spent it's first 5 years going through Chicago winters. When it finally came time to do the O2 sensor, it was an interesting experience.
Soak the studs & nuts in PB Blaster, wait an hour, give it a shot. Repeate as required.
BE CAREFUL - you can EASILY snap those studs off. If you do, then it's a trip to an exhaust shop to get it dealt with.
Old 06-10-2006, 07:40 AM
chugs's Avatar
Has anyone tried gettin' their 02 sensor replaced for free from dealer? It says it in the owners manual that u can get it replaced for free, parts and labor...i think it's on page 156 in owners manual..
Old 06-10-2006, 07:45 AM
HUTCHSTACO's Avatar
what year maual says that?
Old 06-10-2006, 07:52 AM
chugs's Avatar
i have a 1994 toyota pickup 4wd
Old 06-10-2006, 07:55 AM
midiwall's Avatar
There are a couple of threads about this here... you should try searching.
Basically there's a mileage limit on that concept of "free". Call the service dept first before you go in.
edit: searching on "o2 free" turns up:
https://www.yotatech.com/forums/f116/free-o2-sensor-replacment-83724/
There are other discussions as well... Searching's cool. Searching's neat. Searching's the place to be.
Quick Reply: Preference for O2 Sensor Brand?
