Power steering whine Please help!!
Old 11-06-2005, 02:01 AM
OZONE's Avatar
I have a '90 4runner v6 4x4, auto. I have just replaced the power steering pump, and I have a god awfull whine comming from the pump. Not only when I steer but when the brakes are aplied too. whats causing this? Its like I have the wrong fluid in or something. I'm using the factory recomended Dexron III. When I 1st installed the pump it was doing it so I got a exchange for another and still the same thing happens. Anybody have any sudgestion. Its driving me crazy. Thanks
Old 11-06-2005, 06:07 AM
SteveO's Avatar
Did you get all the air out of the system. It takes a while. In the manual there is a method to getting the air out of the system, and making sure you have enough fluid. The only time my PS pump whined is when I didn't have enough fluid. Even now with 37" tires, I don't hear any complaining from the PS pump.
Old 11-06-2005, 07:56 AM
4Crawler's Avatar
I use the bleeding instructions here:
- http://howeperformance.com/bleedinginst.html
And likely you have ABS brakes and the ABS actuator is powered off of the power steering pump via lines off of the steering box.
Old 11-06-2005, 12:25 PM
OZONE's Avatar
OK I'll try that, I thought I bleed the system good with the tires off the ground but I didnt do it this way. It looks like I didnt have the right fluid either, so I'll flush that out to. Thanks guys
Old 11-06-2005, 12:42 PM
4Crawler's Avatar
For an all-Toyota system, ATF is the proper fluid.
Old 11-06-2005, 10:27 PM
OZONE's Avatar
I'm have valovoline dexron III in right now and Ill try to bleed it out again tommorow. I'll post up my results.
Old 11-07-2005, 10:43 AM
OZONE's Avatar
Well I went threw the bleeding process again and the fluid looks perfect and no whining. YAY!!! But its at operating tempeture. We see tommorow when its cold how it does. Thanks guys!!!
Zpd426
01-02-2016 01:15 PM
delmert
09-30-2015 04:34 PM
Up&Down
08-11-2015 10:04 AM
toyoterferdayz
Diesel Swaps
07-27-2015 05:25 PM
gmonnie123
07-26-2015 02:44 PM
Quick Reply: Power steering whine Please help!!
