Old 03-30-2016, 03:02 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Steering & Suspension Guides
Print Wikipost
power steering pump leaks into exhaust
Old 02-03-2008, 02:32 PM
skylinetwo40's Avatar
I have a 94' 4runner and it has a power steering leak. There is NO visible signs of leakage on the lines. If your just ideling and turning the wheel it's fine. But the resevoir drops very quickly when you turn the wheel while driveing. And it also drops quickly when you step on the gas. The exhaust spews smoke and it smells like power steering fluid. I was wondering is there any kind of of vacume line or a valve in a vacume line that could be leaking into the motor. I'm stumpped. Any help is greatly appreciated.
The following users liked this post:
MCompton (11-02-2021)
Old 02-03-2008, 02:58 PM
TORTIS's Avatar
you sure it is not brake fluid?
Old 02-03-2008, 03:14 PM
Brenjen's Avatar
Not possible as far as I'm aware. Unless you have a hole in the manifold neither power steering fluid nor brake fluid can get into the exhaust & it would have to be spraying out at that.
Old 02-03-2008, 06:21 PM
Brenjen's Avatar
Originally Posted by yota4runna
You have an idle-up valve on the P/S pump that compensates for the load on the engine when you turn the wheel and increases the idle. When that valve leaks, P/S fluid is sucked thru the vacuum line into the intake manifold.
You learn something new everyday. I knew there was an idle up function but I was unaware it could get P/S fluid sucked into the engine.
Old 02-03-2008, 06:55 PM
toytech76's Avatar
X2. Ive seen it happen many times
Old 02-03-2008, 07:24 PM
Thanks!! I figured there had to be vacume line on it somewhere.. Due to the nature of it sucking fluid and spewing smoke when I increased the throttle..
Now Does anyone know where I can find this valve?
Old 02-03-2008, 07:51 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Need to know what motor you have first.
http://personal.utulsa.edu/~nathan-b...sm/engine.html
Good call, yota4runna.
Old 11-02-2021, 03:42 PM
MCompton's Avatar
PS fluid leak to exhaust
I own a 2006 Mercedes SLK 350 convertible. No steering problems. No leaks on the ground. However, I smelt my own exhaust every time I drove it. So much so that I would cough. My eyes would burn and I got headaches. My clothes and hair stank!!
Took it to a mechanic associated with the dealership I purchased it from. He replaced the cabin filter. Problem not resolved.
A 2nd mechanic (not associated with the dealership) showed me that the first mechanic did not install a new cabin filter. Had new filter installed. Exhaust smell not resolved.
Ready to sell the car, I took it to a major Mercedes dealership mechanic. Found power steering fluid leaking on to the exhaust. Repaired!
Thanks for posting your concern.
06-01-2021 01:51 PM
TURBOrunnerNM
07-22-2015 11:01 AM
andrewtexas123
07-14-2015 04:29 AM
Avenged
07-09-2015 07:55 AM
Quick Reply: power steering pump leaks into exhaust
