power steering fluid type
Old 12-11-2009, 09:27 AM
lordhowe's Avatar
I have a 92 4runner 5 speed v6. I need to add some more power steering fluid but I am uncertain which grade to use exactly. I know it takes Dexcon ATF but from reading several posts, do i need I II or III? or does it not matter.
thank you for responding to such a newbie question
Old 12-11-2009, 09:47 AM
BoostinChick's Avatar
What does the cap say?
Old 12-11-2009, 10:46 AM
crafthorse's Avatar
If you use DOT III I think it will cover needs for the lower DOT requrements, I think. Someone with a definate answer should be along shortly
Old 12-11-2009, 10:52 AM
lordhowe's Avatar
If you are trying to be serious then the cap says Dexcon Type ATF
if you are being an ass then
Old 12-11-2009, 11:32 AM
clydehatchet's Avatar
the difference between I, II, III, IV, is advancements in technology made between models. IV being the current i believe, dont think you can buy anything less than that. and it might be V now.
Old 12-11-2009, 12:35 PM
RustBucket's Avatar
I just use the ATF in the parts store that is "formulated for Japanese vehicles". Seems to work fine!
Old 12-11-2009, 12:55 PM
lordhowe's Avatar
I got the dexcon III ATF from advanced autoparts. hope it works
Old 12-11-2009, 01:28 PM
Staff
DeathCougar's Avatar
Check the cap...it tells what fluid to put in
Or your owners manual.
Mercon/Dexron 1 supercedes to 2 supercedes to 3. It may be up to 4 now, not sure.
Old 12-11-2009, 01:31 PM
that will work.
Old 12-11-2009, 03:44 PM
tc
tc's Avatar
IIRC, Dexron IV and higher are not compatible with III and lower.
Anyways, Dexron III or even "dexron types" is what you need.
The following users liked this post:
JoeS (01-06-2023)
Old 12-11-2009, 06:10 PM
...that's what I said. I swore mine said Dextron III and the Castor ATF I got says "For Japanese Vehicles" on it. Anyways glad you got it figured out and didn't end up putting PS fluid in it
Old 12-11-2009, 07:38 PM
abecedarian's Avatar
Spec should be Dexron III. Dexron IV is backwards compatible as is Dexron V, as is Dexron VI. And Dex/Merc is compatible too and a lot cheaper.
Old 12-11-2009, 08:23 PM
sb5walker's Avatar
There are three Dexron III compatible fluids that are more viscous than most and are often recommended for power steering. Any of them would be a good choice for a pump that's making noise or a pump that is leaking fluid:
Red Line Synthetic Power Steering Fluid - probably the best all-around choice:
http://www.redlineoil.com/product.aspx?pid=79&pcid=27
http://www.redlineoil.com/content/files/tech/49.pdf
(Normally, you should avoid "Power Steering Fluid" and stick with Dexron ATF, but Red Line's product meets the Dexron III spec.)
Castrol Import Multi-Vehicle Automatic Transmission Fluid (ATF):
http://www.castrol.com/liveassets/bp...s_ImportMV.pdf
and, CHEVRON MULTI-VEHICLE ATF:
https://www.cbest.chevron.com/genera...DS27291691.PDF
If the vehicle is operated in very cold environments, a less viscous synthetic ATF fluid would be a better choice. The best probably is:
AMSOIL Synthetic Automatic Transmission Fluid:
http://www.syntheticwarehouse.com/Specsheets/ATF.pdf
and, MOBIL 1 SYNTHETIC ATF is also very good:
http://www.esso.ca/Canada-English/Fi...thetic_ATF.pdf
Both of these are less viscous (thinner) than the first three mentioned, and would be more liable to have leak issues in warm weather, but they are both excellent fluids.
Old 12-11-2009, 08:42 PM
And now we know why GM won't license "Dexron" for older products- there isn't any consistancy between brands and GM owns the trademark.... and the fact that GM won't license it may be the reason for lack of consistancy.
Old 12-11-2009, 08:44 PM
Personally, I would avoid any synthetic Dexron III compatible fluid.
Old 12-11-2009, 08:46 PM
sb5walker's Avatar
I've been using Mobil 1 for years and it works great.
Old 12-11-2009, 09:04 PM
sb5walker's Avatar
https://www.mobiloil.com/USA-English...exron_III.aspx
http://forum.ih8mud.com/80-series-te...hetic-atf.html
http://www.bobistheoilguy.com/forums...Number=1090825
Old 12-12-2009, 01:49 AM
gary96360's Avatar
my truck had powersteering fluid when i bought it so i was like screw it and poured in ps fluid lol
Old 12-12-2009, 04:25 AM
RustBucket's Avatar
Originally Posted by Gnarly4X
Dexron 1,2,3,4,5, 12, 13, synthetic... blah blah blah... Your power steering pump won't know the difference!!
Now that's what I call Yota "tech"!
Old 12-12-2009, 04:42 PM
Staff
Well, which is it?!
Quick Reply: power steering fluid type
