Power steering fluid and ATF dexron 2 different?
Old 01-21-2009, 11:10 AM
simpsons721's Avatar
Hi
im out of power steering fluid. I bought prestone power steering fluid but when i was about to fill my runner it says to use atf dexron 2.
Basically can i use the preston stuff
also how much does it take to fill the compartment
i know its a newb question i need a quick reply
thanks
matt
Old 01-21-2009, 11:13 AM
Godzilla's Avatar
Only ATF.
DC.Woods's Avatar
Use ATF power steering fluid can damage the seals.
Old 01-21-2009, 11:14 AM
mt_goat's Avatar
Use only ATF.
thank you all
Old 01-21-2009, 11:15 AM
waskillywabbit's Avatar
Use what it says to use or you will regret it. They put that sticker on the PS reservoir for a reason.
Toyotas use ATF (Auto Tranny Fluid) in the power steering system.
Old 01-21-2009, 11:41 AM
tc
tc's Avatar
x6 - ATF unless you like replacing power steering pumps
Old 01-21-2009, 05:14 PM
Matt16's Avatar
I've topped the system up with PS fluid. Hasn't been a problem yet, but I only added a little bit. I plan on syphoning out the old fluid and replacing it with ATF sometime.
Old 01-21-2009, 05:31 PM
bigt's Avatar
only use atf..
you toyota will like you.. if u use power steering it wont like you
Old 01-21-2009, 07:00 PM
Just Learning's Avatar
I use in all my trucks torco atf doesnt varnish , take the heat
Old 01-28-2009, 09:42 PM
gary96360's Avatar
ive noticed that i have powersteering fluid in my truck today, bought it a couple of months ago. is it easy to drain the fluid out of the system. do you just take the hose off the pump and then drain it and start truck up and turn side to side to get it out of the system
Old 01-29-2009, 03:54 AM
GSGALLANT's Avatar
Here's a writeup for you... it will work the same on your pickup.
Old 01-29-2009, 12:52 PM
tc
tc's Avatar
If you've had it in there a couple months, the damage is probably done if it's going to be ... I would leave it in, and purge the system when you need a new PS pump. You may be one of the lucky ones ...
Old 01-29-2009, 01:20 PM
bigt's Avatar
x2 you might cause a leak by switching... some time stuff likes to snow ball
Old 01-29-2009, 01:54 PM
Staff
DeathCougar's Avatar
I think you should try using some 710 fluid
Old 01-29-2009, 01:59 PM
Jay351's Avatar
x7, been there, done that....
Old 01-29-2009, 04:04 PM
gary96360's Avatar
it looks like the ps fluid has been in there for a long time because its dark in color. and i'm sure its ps fluid because of the smell. and also the fluid level is pretty low. so should i fill it right up with ps fluid or just wing it and put in atf and hope the pump doesn't leak. are the pumps pretty expensive?
Old 01-29-2009, 06:05 PM
tc
tc's Avatar
Nah - only like $50, but a MAJOR PITA to replace on a 3.0 ... definitely one of those "you have GOT to be kidding me" jobs that there seems to be a bunch of with the 3.0.
Old 01-29-2009, 06:30 PM
abecedarian's Avatar
Unhappy
Are you sure I shouldn't use Dexron II or maybe Dexron III, or DexMerc and does it go in the 710 cap, the break cap or the power steering fluid cap?
Old 01-29-2009, 07:08 PM
gary96360's Avatar
also add headgasket job to the "you have GOT to be kidding me" list. yeah 50 bucks doesn't sound that bad. do you think that other parts of the steering system has to be replaced other than the pump ect the steering box if it is contaminated with ps fluid.
Quick Reply: Power steering fluid and ATF dexron 2 different?
