Post your ISR Mod Pics!
Old 02-04-2009, 07:22 AM
  #61
flashkl's Avatar
Bump for my question above, what are all of you exhaust pipe ISR mod people doing to keep the intake from getting super hot?
Old 02-04-2009, 08:04 AM
  #62
qdude79's Avatar
Any thoughts/opinions on whether or not the ISR mod would be "worth it" if I were to keep the stock airbox? Just bought a drop-in for it and would like to keep it.
Old 02-04-2009, 08:20 AM
  #63
flashkl's Avatar
That's the whole (ok, maybe not whole but most) point of the ISR mod: retaining the protection from crud by using the stock aribox, and removing the obstructions in the intake tube itself.
Old 02-04-2009, 08:24 AM
  #64
qdude79's Avatar
Got it. Just saw a lot of cone filters and didn't know if that was considered the bottleneck that people were trying to get rid of...
Old 02-04-2009, 01:03 PM
  #65
Chief_Yota's Avatar
Originally Posted by iamsuperbleeder
no brakes?
im in the middle of a Buildup,lol,sas,rear disc swap and so much more,link is in my signature!
Old 02-04-2009, 03:56 PM
  #66
Dublin's Avatar
if your worried about heat some use header wrap. I just don't worry about it, the engine bay temp is what it is. If those using pvc don't have a problem, I don't think the temps get that high (unless it's hours idling in summer grid-lock). I've heated up pvc to bend it by sticking it in a tail pipe (us electricians will try anything) and it doesn't take too long. The exhaust gets a lot hotter than the engine bay IMO.
Old 02-04-2009, 05:43 PM
  #67
flashkl's Avatar
That's what I wanted to hear...thanks!
Old 02-13-2009, 05:07 PM
  #68
Jewels's Avatar
here's mine i made from an old civic intake. its not pretty but it works
Before
[IMG][/IMG]
I cut it to size and left a little of the curve to it. and left the two hose connections.
[IMG][/IMG]
put it in place, and connected the hoses.
[IMG][/IMG]
fits a little tight, but works good.
[IMG][/IMG]
love to hear this baby suck air as it compliments my magnaflow exhaust.
[IMG][/IMG]
Old 03-08-2009, 11:51 PM
  #69
sinneDBTB's Avatar
whats a good non oiled filter? i bought my setup on ebay but the filter sucks and spills oil like the exon-valdes.
Old 03-09-2009, 02:58 AM
  #70
flashkl's Avatar
Toyota OEM filters are very good. I'm using a NAPA one right now, nothing bad to report, but I think I'm gonna go back to Toyota for the next one.
Old 03-09-2009, 01:46 PM
  #71
sinneDBTB's Avatar
the toyota oem filter in the air box? i meant a cone filter.
Old 03-09-2009, 01:59 PM
  #72
flashkl's Avatar
Oh, my bad. Not too sure on any non oiled cone filters...
Old 03-09-2009, 02:08 PM
  #73
sinneDBTB's Avatar
anyone else using a cone find that the oil seeps out and causes the maf to malfunction?
Old 03-09-2009, 02:59 PM
  #74
Jay351's Avatar
You have a VAFM, not a MAF. Two completly different air metering devices. Your Vafm should not be affected, but your TPS can be.
p.s stock is true cold air intake. Those cone filters reduce horsepower by sucking in hot engine bay air.
Old 03-09-2009, 05:28 PM
  #75
CoedNaked's Avatar
I would get an Amsoil Ea Cone filter. The best on the market for the application.
Old 03-09-2009, 05:48 PM
  #76
4banginRunner's Avatar
22RE Battery/Intake swap
$0
Heater duct from 79-83 Pickup, filter was snagged at the junkyard, AFM adapter is 2.5" exhaust tubing and 1/8" plate, and I had the wires and loom.
Old 03-09-2009, 08:28 PM
  #77
sinneDBTB's Avatar
i didnt realize there was a difference, my haines manuel calls it a maf i'm pretty sure. anyways you recomend using the stock airbox setup with the isr mod?
Old 03-09-2009, 08:48 PM
  #78
awareness's Avatar
That's typically how most people here seem to setup their ISR mod, because it's a matter of simply removing the intake silencer assembly and not the airbox as well.
Old 03-09-2009, 08:50 PM
  #79
xzyragon's Avatar
have to post mine...
i plan on making a shield around it and drilling a hole in the wheelhousing to let it breath some nice fresh air...
Old 03-09-2009, 09:17 PM
  #80
toylocost's Avatar
Location: Yotatech, because Pirate is too expensive. NorCal.
Corragated tube. Great for smooth airflow.
Quick Reply: Post your ISR Mod Pics!
