Polishing my intake - ocd can help sometimes lol
Old 06-05-2009, 04:04 AM
SwampThing's Avatar
Originally Posted by iamsuperbleeder
lmao, you first
then do your entire frame!
We both know the only thing I'm OCD on is destroying my trucks.
*Driving slowly down the beach* "Oh look, it's something different!" *Rollover*
I've only once washed the ST2 since I've had it.
Old 06-05-2009, 06:42 AM
flashkl's Avatar
shiny shiny. I say dress it up with some rhinestones and a bedazzler.
Old 06-05-2009, 07:18 AM
aviator's Avatar
LOL you gotta know some rapper some where is going to get the idea to do up his intake with diamonds/rhinestones/cubic zirconias to add some bling to his ride...
Old 06-05-2009, 08:44 AM
Jay351's Avatar
so damn funny!
Old 06-05-2009, 09:03 AM
  #25
mrddk92's Avatar
I was thinking it might be fun to just do the whole truck haha. Who needs paint when you can have polished sheetmetal?
Old 06-05-2009, 03:12 PM
  #26
iamsuperbleeder's Avatar
as long as that would take, it might look cool!
lol
finish it off with 2000 grit, and just spray it with clean coat, and BAM!
Old 06-05-2009, 03:33 PM
  #27
mrddk92's Avatar
Haha lol. Has anyone seen the toyota a-bat? Its a hybrid concept truck but it loooks all metallic.
Old 06-05-2009, 03:45 PM
  #28
flashkl's Avatar
Old 06-05-2009, 04:17 PM
  #29
Boyd Coddington's Alumitub
Old 06-05-2009, 04:32 PM
  #30
mrddk92's Avatar
haha those are cool i wonder how the a-bat would do offroad i wish they would just bring back the gen3 trucks and give em more power and economy that would be awweessome but i gues the majority like the big bubble trucks haha
Old 06-05-2009, 06:01 PM
  #31
ovrrdrive's Avatar
I'm guilty too... And as TN said, it gets all crappy looking after about a month. I'd try to strip all the grease off of it with some acetone and spray clear on it if I were you. Once the engine is put together you won't be able to do it.
Old 06-05-2009, 06:17 PM
  #32
well hell, before paint, both my upper and lower manifold's looked quite similar; but of course I only have a pre-paint pic of my lower manifold
you wanna talk about something that's a PITA to clean...
granted it's not polished, but it still takes a long time...
and they turned out like so:
Old 06-05-2009, 07:02 PM
  #33
mrddk92's Avatar
haha yeah i can still see the casting surface dimples and stuff, mine is a lil smoother lol so it shouldnt collect so much dirt and stuff i hope. i almost just sanded the letters completely off because it was a pita to sand and polish all around them, i did take off the double ridge part though......right where the flat part in the middle meets the part where the letters are
Old 06-05-2009, 07:05 PM
  #34
mrddk92's Avatar
i still neeed the inside cleaned, i think ima take it to a machine shop for that but idk i got most of the larger deposits out so idk how much the rest will effect the performance. there was like 1/3 of an inch of buildup where the egr comes in
Old 06-05-2009, 07:28 PM
  #35
desertcamper67's Avatar
What about the build up on the inside? Can that be cleaned up a bit on the truck or will debris falling down into the lower part and eventually into the cumbustion chamber do any damage? I just took off my throttle body to clean it up and address the TPS.
I couldn't believe what I found behind it. Its like thick, moist brownie residue stuck to the pan. Comes off with the finger but I want to spray some throttle body cleaner in there and see metal again. Is this a good idea?
Old 06-05-2009, 10:30 PM
  #36
mrddk92's Avatar
Idk I would take it off to clean it. But some tb cleaner can't hurt really, I would use that but don't go. Scrapin away, there's a lot o stuff in there. But even with it off its near impossible to get all that out. Its all just exhaust deposits. Uuugggh.
Old 06-05-2009, 11:10 PM
  #37
mikelusk1's Avatar
delorean came in stainless steel from the factory
and this is just plain shiney
Old 06-06-2009, 08:30 AM
  #38
Okay I will take it off today. I just looks so bad I want it gone.
Old 06-06-2009, 09:57 AM
  #39
totally a bro
Staff
vital22re's Avatar
while you've got the manifolds off, you should gasket match everything. may help with the cams
Old 06-06-2009, 10:31 AM
  #40
mrddk92's Avatar
was that to mee? i wanted to get my heads ported and get o/s valves but i couldnt justify 850$ for like 10 hp maybe. it just aint worth it, ima be fine withe headers and cams i think. eventuall im get a 3.4 so i just want my 3.0 to last untill i can do that...i might do some gasket matching though. would just use a dremel with an aluminum oxide grinder ? or i could prob use a drill
Quick Reply: Polishing my intake - ocd can help sometimes lol
