Philbert's 87 4runner W56 tranny swap/build thread
Old 05-21-2012, 04:22 AM
  #161
irab88's Avatar
awesome. when you pulled the tranny out again, did you find it easier to do? did you do anything different? just wondering, in case i need to do mine again
Old 05-21-2012, 05:07 AM
  #162
Philbert's Avatar
Ian,
I had a buddy to help pull and replace..made a world of difference. No tied downs needed this time !
Old 09-06-2012, 06:18 AM
  #163
junk4u's Avatar
Crankshaft Sleeve
Nice job philbert's, I remember taking the tranny down 3 times in one day to change it out.
I have a question, Where did you get the crankshaft sleeve and if you have a sku # or a part number please post.
Thanks
Old 09-06-2012, 06:31 AM
  #164
Philbert's Avatar
Thanks!
I got the sleeve at an auto parts store. Not a yota part...just call and ask if they have one for your model and year...I think it was fel pro.
Old 09-06-2012, 08:05 AM
  #165
junk4u's Avatar
Originally Posted by Philbert
Thanks!
Hey thanks for that info. I'll check it out when I get the chance at the auto parts store.
By the way have you ever heard of changing the tail housing and shift rails in a W56 Forward tranny for the tail housing and shift rails in a top shift tranny?
Just curious as no one else seems to want to answer my question anywhere I've posted. It seems that there are more forward shifters than tops considering the ages.
Old 02-06-2020, 12:02 PM
  #166
Papadeath's Avatar
Originally Posted by irab88
this is what i did:
-tranny on jack
-line up tranny with engine
-insert input shaft to clutch/pilot bearing
-bolt t-case mount to x-member
-bolt x-member to frame
(at this point, the t-case mounting holes should be out of line with the mount's holes, but the t-case will rest in the mount)
-work the tranny until you can get the 2 17mm bolts in (the ones on the sides)
-once everything is lined up, tighten those bolts to pull the tranny to the engine
-get all the other bolts
that's how i did it, and it worked just fine for me. i never tried the way you're going to do it, but it should work about the same (as in good results). when you mount the t-case mount, leave all the bolts loose so you can slide it around a little bit if you need to.
and something i had to keep reminding myself of: the trans will only raise so far before it hits the tunnel. you probably are already aware of this, though
let me know if you need anything else
I try to stay clear of pulling the tranny forward by tightening the bolts, unless maybe less than half an inch or so. Gremlins can still cause binding somewhere and you don't want to force anything. I jiggle the tranny best I can as far as it will go before putting any torque on the bolts. Otherwise it'll ruin your afternoon.
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
Jnkml
07-06-2015 01:20 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Philbert's 87 4runner W56 tranny swap/build thread
