Pest Coolant Leak! Temp sensor
Old 03-10-2006, 07:23 AM
cruisinforburgers's Avatar
Hey Y'all. my 22re motor is leaking coolant out of one or both of the temp sensors on the front of the Intake manifold. the ones that are side by side that the harness plugs into. it's not spraying out, but every morning i'll check it and there is some residule leakage alomost jelled radiator fluid there. looks like they have copper crush washer gaskets behind them, any suggestions.
doubt there a cheap part from the Stealership.
Old 03-10-2006, 11:49 AM
eric-the-red's Avatar
Replace the copper washers, shouldn't cost more than a buck or so, or maybe try Teflon tape on the threads.
Old 03-10-2006, 12:27 PM
Flash319's Avatar
make sure it is not dripping from the High speed idle unit above it. Fluid runs through there to and may be dripping onto the sensors.
the1998sr5
15
07-14-2020 08:35 PM
WellsR
12
07-31-2015 03:27 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Avenged
07-09-2015 07:55 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: Pest Coolant Leak! Temp sensor
